Car Scanner Pro Issue
BSull
Robert
Mesa, AZ
Corvette, F150 Lighnting, Mercedes GLC300
Purchased the forever license for car scanner ELM Pro. Lately I've been getting "available in pro version" alternating with the data about 1 second cycle. The app even says car scanner pro in the title bar. Anybody else have this issue?
fvineyard
Frank
Virginia, US
2023 F150 Lightning XLT ER, 2023 Hyundai IONIQ 5
IT Manager
No issues with Pro version for me. Maybe try Contact Developer option in the Settings Menu. There is an option for Purchase Related issue as one of the choices there so I would bet money this has happened to others if it rates having a distinct menu option :)
BSull
Robert
Mesa, AZ
Did that, reply was to force close the app then try again. I had already done that but will do as requested.
fvineyard
Frank
Virginia, US
IT Manager
The only other suggestion I can make (and you may have done this already too) is force close, clear data and clear cache. If that does not work I have no other ideas. Well, maybe uninstall and reinstall after that.
ryry
Ryan
Nashville
Lightning Lariat ER
I had the same issue. I had to delete the app and reinstall and it resolved the problem.
BSull
Robert
Mesa, AZ
I force closed the app again, restarted phone, disconnect OBD sensor. Turned everything back on and Car Scanner worked. Problem solved, “if in doubt, reboot”
fvineyard
Frank
Virginia, US
IT Manager
Glad you figured it out and shared the fix in case it might help others too :)
