dingmah
- Nov 12, 2023
- Edmonton, Alberta
- Lightning
Can I get a check for 1FTVW1EL3PWG12195? Thanks in advance.
Thank you so much!Truck is on the latest Sync version. Modules with pending updates are below.
Is there a way force/push these updates?Truck is on the latest Sync version. Modules with pending updates are below.
Your truck is also on the latest Sync and seems to have been updated with FDRS at some point as there are certain updates already applied that can only be done with FDRS. You aren't getting updates because there isn't much that needs to be updated.Could you also check 1FT6W1EVXNWG14528? I feel like I got a bunch of updates 4 or 5 months ago and nothing since.
Thanks.
The only way to do it is to invest in the tools needed for FDRS and do them yourself. There is no way to speed up the OTA process.Is there a way force/push these updates?
Hi Javier, thanks for this serviceHello all,
I wanted to start a thread here for people to want to get their VINs run through PTS or FDRS. Anyone that has PTS or FDRS access, please feel free to jump in the thread and provide info if a request is made.
PTS shows OTA history and/or if you have any active OTA triggers waiting to install on your vehicle. You can also pull window stickers, see what DTC's the truck is reporting to the cloud (this only works if you have your Fordpass set up), pull up wiring diagrams, check for open recalls, warranty history, and more.
FDRS checks will show all modules on the vehicle that have a pending update on Ford's server. This can also be done with PTS, but it is not as accurate as FDRS. Any questions about the FDRS process, please refer to this thread; let's keep this one specific to VIN checks and not FDRS procedural questions:
https://www.f150lightningforum.com/forum/threads/lightning-software-updates-using-fdrs.11029/
If you prefer to not post your VIN publicly on the forum, feel free to message me privately. In your request, please specify what you need checked. OTA history? Modules pending updates? Why is an OTA failing? etc
Note: If you want an FDRS specific check, please note that I only have FDRS access in the evenings when I am home with my laptop. Unless someone else with FDRS access can chime in, any specific FDRS checks would have to wait until I am home for me to do.
Truck is on the latest Sync version and has a healthy OTA history. Modules pending updates are:Could you check 1FT6W1EVXPWG60654, please?
Truck is on the latest Sync and has no recent OTA history. Not much pending, though.First, thank you for this service. It is much appreciated.
Would you check 1FT6W1EV6NWG04076?
Sync 6.4 is the latest? I thought it was 6.14. I still don’t have the SoC on the dash and or the Tesla PnC updateTruck is on the latest Sync version and has a healthy OTA history. Modules pending updates are:
