BeeKind
- First Name
- Jim
- Mar 1, 2024
- Long Island, NY
- '23 F150 Lightning, '23 Ioniq 5
I don't have a lot of electron knowledge, just enough to get me in trouble. I'm going to make a few statements that I'm looking for you electricians/engineers/smart people to correct if I'm wrong. Then my questions, thanks in advance!
- AC circuits always have current being supplied and when devices turn on they draw off the current being supplied
- The truck always supplies at least some 120v AC current to the in-cabin outlets when the truck is on
- The truck must be on to operate any receptacles/circuits
- When you toggle a circuit on, it puts some current on that circuit
- This doesn't appear to be full current (ie, it's not supplying 2400W to the 20a circuit)
- They appear to step the current up to draw
- Observed via BBU connected to circuit kicking on when A/C compressor kicked on
- Sustained current draw (1500W to 120v) has no problems
- The cabin outlets are not attached to the bed circuits
- This creates a situation where you can't access the outlets that always have idle current running.
- IE, if it's raining you can't have extension cords coming from the cabin with open door or window. So you come off the tail and you're always wasting energy in the cabin
- The two tail 120v circuits should be thought of as a kind of sub panel to the 240V 32A circuit.
- What is the minimum idle current draw if nothing is connected to the truck.
- Climate off in cabin
- Screen off in cabin
- Headlights off
- What is the minimum idle current draw on frunk circuit?
- What is the minimum idle current draw on the tail circuit(s)?
- What are the stepup increments? IE if it calls for 200 watts does it jump to pushing 1000? 500?
