ExCivilian
How would reversing the flow of electrons circumvent electrical safety features in a home system?
Breaker is at the wrong end of the circuit and doesn't protect the wiring.How would reversing the flow of electrons circumvent electrical safety features in a home system?
If that's a concern, how would that be different in the context of using the correct extension cord from a generator to the home?Breaker is at the wrong end of the circuit and doesn't protect the wiring.
^^^This^^^Or am I completely confused on the problem here and that the issue is people might be plugging their extension cords into a kitchen outlet, for example, the run the house during a power failure rather than running their main panel from a generator?
Actually with Alternating Current (AC) the flow is both ways all the timeAnd now that we're talking more about it I'm confused on how using a generator "reverses the flow" of electrons. They're moving the same direction they would be if the outside power was a utility company instead of the generator.
That's what I originally thought and why I question what the statement "reversing the flow" of electrons even means.Actually with Alternating Current (AC) the flow is both ways all the time![]()
But do you know if they're referring to people plugging an extension into an outlet on the inside of the house? I don't see how using a male to male extension to connect to a main panel is any different from using a male to female extension or female to female extension.A properly configured panel will not need a male to male cable
1) A properly installed inlet that accepts the female end has to be properly sized to handle what the generator can deliver. The breaker on the generator will trip before a problem occurs.That's what I originally thought and why I question what the statement "reversing the flow" of electrons even means.
Has anyone figured out a work around to this problem?The metal interlocks are cheap and effective. I had the electrician install one and a 30 amp generator plug. Unfortunately the bonded neutral issue is causing it to not work at all.
