dustintinsley
Can I get an update on mine now that some updates were completed?
1FT6W1EV3PWG50077
1FT6W1EV3PWG50077
Only showing a BCM update, but you're not on the latest Sync. Seems like your truck is affected by an issue where the next update you need to fully update the APIM/GWM/TCU modules does not show for you. It is unknown if this is on purpose from Ford's side or if it is due to an issue they need to address.Can I get an update on mine now that some updates were completed?
1FT6W1EV3PWG50077
You are on the latest Sync, but as expected as has happened to 99% of the people who ask dealer to update everything, that was not done. Ford does not pay dealers to do module updates just because they are not up to date and nobody likes to work for free. Dealers only get paid to do updates if there is a recall tied to the update or the update will fix a problem the vehicle has. They did do a GWM and APIM update which got you to the latest Sync version you are now on, but they did not do ALL updates.Hi all,
Was hoping I could get a VIN check on a Ford a Lightning I've only owned for about a month. I was working with Ford and they did have me take it in to the dealer to have Sync updated. it's now on version 4.0.23291. I was told it has no other updates to be applied by the dealer.
VIN: 1FT6W1EV5PWG05271
Thanks,
Larry
Thank you. Hopefully those updates will get dropped for me soon. Thanks again!Only showing a BCM update, but you're not on the latest Sync. Seems like your truck is affected by an issue where the next update you need to fully update the APIM/GWM/TCU modules does not show for you. It is unknown if this is on purpose from Ford's side or if it is due to an issue they need to address.
Thanks for the quick reply. So looking at the list of items to be updated, do you think they'll get updated on their own? Would you recommend getting on the list for the Mongoose cable and doing the updates myself? To me the TCU is probably the biggest concern, could it prevent OTA updates going forward?You are on the latest Sync, but as expected as has happened to 99% of the people who ask dealer to update everything, that was not done. Ford does not pay dealers to do module updates just because they are not up to date and nobody likes to work for free. Dealers only get paid to do updates if there is a recall tied to the update or the update will fix a problem the vehicle has. They did do a GWM and APIM update which got you to the latest Sync version you are now on, but they did not do ALL updates.
All the updates there will come OTA except the IPMA/PSCM updates that are not being sent out OTA yet.Thanks for the quick reply. So looking at the list of items to be updated, do you think they'll get updated on their own? Would you recommend getting on the list for the Mongoose cable and doing the updates myself? To me the TCU is probably the biggest concern, could it prevent OTA updates going forward?
Thanks,
Larry
Awesome! You are only showing a BCM and ACM update pending. The ACM is known for not coming off the list after it is applied, so you only need the BCM OTA to be fully up to date now.Hello again! 6.8 finally showed up for me today. Can you check my VIN to see what else Ford may be showing for my truck now? Thanks!
1FT6W1EV9PWG51864
Awesome! The 23B57 CSP is still showing on my FordPass. Should I also have a BECM update pending? Or does that not show while Ford has them on “hold”?Awesome! You are only showing a BCM and ACM update pending. The ACM is known for not coming off the list after it is applied, so you only need the BCM OTA to be fully up to date now.
If you updated the BECM yourself, then it will still show open because only the dealer can clear that out from the system. My truck still shows 21G01 for BC programming open and I've had BC for years at this point.Awesome! The 23B57 CSP is still showing on my FordPass. Should I also have a BECM update pending? Or does that not show while Ford has them on “hold”?
Makes sense! Are you able to see if I did that one myself? I updated so much that I can’t remember what all I did lol.If you updated the BECM yourself, then it will still show open because only the dealer can clear that out from the system. My truck still shows 21G01 for BC programming open and I've had BC for years at this point.
thanks! I guess I’ll need to reach out to the dealer once they lift the hold on powertrain module updates.These are the ones you did. BECM is not there.
