00SVT
- First Name
- Jay
- Jul 5, 2024
- NJ, Middlesex County
- 24 Flash, 00 Lightning
- Occupation
- Utilities
First and foremost- I did not know the seats reclines so far. What a nice feature- I must have been under a rock when it was discussed
With that being said, it took me all of 10 minutes to install a console safe. I went with Console Vault. I also added their Elite Lock and Lodestar interior led
Easy install- you need 11 & 13 mm short 1/4 drive socket, a ratchet and a 1/4 manual driver (directions call for fractional but I am not going into the garage for them and went with metric). Donāt get fancy like me and struggle- after installing 3 of the 4 bolts with the driverā¦ā¦.yep should have used the ratchet. The hardest one went in the easiest.
Anyone who doesnāt like to turn wrenches- next to floor mats or a screen protector- this is probably the best, easiest, and usable mod for the interior.
Not the only safe maker in the game- but the quality is stellar. Easy, diy install, and you can still use the internal USB. No idea that was even there.
Only negative is the tray doesnāt fit. Big positive is the safe lid props up the arm rest so it doesnāt close and piss you off for the 1000 time.
***instructions say to remove the rubber mat on the bottom***
Helps with install because you can slide it around to align.
