Comarley
Thank you. I ended up getting a similar one (I needed a bit more weight capacity).Bought it off of Amazon for $60. There are more expensive ones if you need something sturdier.
Here the Link
Here the Link
Do you mind posting a link?(I needed a bit more weight capacity)
Thanks
I have that model, its good enough for the price when you cant get a full length bed. No load issues so far but plywood and dimensional lumber are all it has seen with most of the weight being carried by the bed as others have mentioned. It is a little wobbly and makes a lot of noise when not loaded but loaded and strapped down its solid.Here is a link to one rated at 750 lbs. That's the highest load rating I have seen. If you google hitch mount bed extender you will see a number of options available.
You got it to fit?My 13 Limited OEM bed extender fits my 23 Platinum grest
There are a couple of versions. This one is for 2015-2024 and is aluminum:You got it to fit?
I have one for a 17 Raptor (which I brought over from a 2016 Lariat) when I asked the dealer to swap it over to my new 2023 lariat Lightning they said it wouldn’t fit
clicked your link just to see it.Bought it off of Amazon for $60. There are more expensive ones if you need something sturdier.
Here the Link
Your occupation?There are a couple of versions. This one is for 2015-2024 and is aluminum:
https://accessories.ford.com/f-150-2015-2021-bed-extender-1
Also a fiberglass/plastic one: https://accessories.ford.com/bed-extender/
Says 2021-2024 but maybe that's when it came out.
I independently verify anything a dealer says . See my occupation:
