8’ bed mod?
Fastnf
CALIFORNIA
2023 F150 lightning
Do you mind posting a link?
Thanks
Here is a link to one rated at 750 lbs. That's the highest load rating I have seen. If you google hitch mount bed extender you will see a number of options available.
GingerBear85
2023 F-150 Lightning Lariat ER - Stone Metallic
Construction
I have that model, its good enough for the price when you cant get a full length bed. No load issues so far but plywood and dimensional lumber are all it has seen with most of the weight being carried by the bed as others have mentioned. It is a little wobbly and makes a lot of noise when not loaded but loaded and strapped down its solid.
Fyatrk
Christopher
Tecumseh, ON
F-150 Lighting , Tesla Model Y
My 13 Limited OEM bed extender fits my 23 Platinum grest
You got it to fit?
I have one for a 17 Raptor (which I brought over from a 2016 Lariat) when I asked the dealer to swap it over to my new 2023 lariat Lightning they said it wouldn’t fit
You got it to fit?
There are a couple of versions. This one is for 2015-2024 and is aluminum:
https://accessories.ford.com/f-150-2015-2021-bed-extender-1
Also a fiberglass/plastic one: https://accessories.ford.com/bed-extender/
Says 2021-2024 but maybe that's when it came out.
I independently verify anything a dealer says ;). See my occupation:
Fyatrk
Christopher
Tecumseh, ON
Your occupation?
Yes, the second one is the actual one that they took off my 2017 I should try to put it on myself. Thanks.
