Noise from shifter after shutdown
Nlrkoa
Larry
Arkansas
2023 Lightning
I have been getting the powertrain malfunction warning every day for a couple of months now. Now the shifter makes noise after I turn the truck off. What is going on?
Ford F-150 Lightning Noise from shifter after shutdown 1000009766
I don't have audio on this PC (yeah it's a weird work PC) but based on previous postings here, I'd say you have a bad shifter. Several have mentioned getting that warning and the dealer diagnosed it as needing a new shifter.
Sounds like bad shifter motor. I always put in Park manually rather than have the motor do it, so who knows, mine may be bad too!
Ford Motor Company
Official Ford Account
F-150 Lightning
Good morning, I would like to see if I can assist you with your noise concerns. Could you please send us a message with your VIN and mileage?
Nlrkoa
Larry
Arkansas
2023 Lightning
I have already sent you all the information before but here goes again.
1FT6W1EV0PWG58332
3700 miles
2022 F150 Lightning Lariat SR Mannequin
1FT6W1EV0PWG58332
3700 miles
Don’t waste your time mate. They just ask your location and give you the dealership info and pass along some platitudes. Ford Corp. has zero power to move you up the queue or make anything happen at the local dealer level.
This seems just like a marketing good vibes thing they do here.
Just call your preferred dealer and see when they can get you in. Call around to others if they are booked out
foxfire235
Steve
Roanoke, VA
2023 Lightning Lariat
Real estate
bad shifter motor. You can buy the part online and replace it yourself. I did it to my lightning.
JohnsonEJ23
EJ
Mesa, AZ
2023 Ford F-150 Lightning Lariat Extended Range
I had the same service error and noise on my shifter. When I took it in the dealer said the powertrain error was pointing to a bad shifter actuator (motor to move my shifter). They replaced it under warranty and all has been fine since.
Maineiac12
Iowa
Did the dealer replace your shifter? Mine just started doing the same thing today.
Nlrkoa
Larry
Arkansas
2023 Lightning
Goes in Monday. We will see.
FloridaMan655321
1973 F100, 2024 Flash
Is this a known issue for certain models? Just curious as I see all who posted were in 2023 models.
ryry
Ryan
Nashville
Lightning Lariat ER
I had it and shifter was replaced. 23 model
