Anyone bought and installed the Eibach Pro Kit?
Mcfly
Billy
Socal
23 Pro SR
Realtor
Okay got the 2 inch lowering shock spring mounts and Icon camber kit installed. It lowered the rear 1.5 inches, taking half of the rear rake out. The ride is exactly as it was stock. In my opinion it looks much better, raked more like an Ice truck comes stock.
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? 20240806_124735-COLLAGE~2
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? 20240806_124857-COLLAGE~2
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? IMG_20240806_084314654_HDR
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? IMG_20240806_084344152_HDR
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? IMG_20240806_084340459
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? IMG_20240806_084357063
Schroederhc1
Cordell
Wenatchee WA
2023 Lightning XLT ER, 1990 911 Targa
Self Employed
Looks nice. I did the same with mine
invertedspear
AZ, USA
lightningcalcs.pages.dev
I dunno, it just looks brighter stock and all washed out lowered. :ROFLMAO:
Yeah, this does look better, I'd really like it to be adjustable for when I do haul something heavy, but this is preferable 99% of the time. Have you done any analysis of efficiency? I would think reducing that rake would make for a slightly lower profile and better mileage, but perhaps it's too minute to make any measurable difference.
Mcfly
Billy
Socal
23 Pro SR
Realtor
I haven't driven it enough to notice any efficiency gain. The truck still has an inch and a half of rake. Should be more than enough to haul some weight and not look like a Carolina squat.
Mcfly
Billy
Socal
23 Pro SR
Realtor
Yup, I got my inspiration from you and another forum member after you guys had a bad experience with the Eibach spring kit.
Mcfly
Billy
Socal
23 Pro SR
Realtor
I'm hopeful someone comes out with a similar solution that lowers the rear a full 3 inches.
TMS
Alberta
23 Lightning
Nice, dumb question what is a 2 inch lowering shock spring mounts
Mcfly
Billy
Socal
23 Pro SR
Realtor
Deleted member 13099
Guest
I had the Hellwig sway bar installed today. It is both larger in diameter and solid. Body roll was almost completely eliminated and the torque steer under hard acceleration is completely gone. I did have the Eibach lowering springs and sport shocks installed at the same time so part of the difference could be attributed to the lowering kit.
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? IMG_2016
KHines
Kevin
Delaware
Mcfly
Billy
Socal
23 Pro SR
Realtor
I’ve looked at this product but there aren’t any instructions - these replace the lower spring platform on the rear shocks? They just slip on, or cut/weld?
I'm not 100 sure, I had them shop installed. But I believe after removing the rear shocks you just slip the original spring mounts off and slip the replacements on.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
Looks great. Just ordered the McGaughy's kit. But is that Icon camber kit really 400 bucks?
Mcfly
Billy
Socal
23 Pro SR
Realtor
It is unfortunately, I think I found it slightly cheaper. Side note I'm not entirely sure you need it. The wheels might stay within spec with the 1.5 inch drop. Might be worth installing the McGaughy's kit and checking before doing the icon camber kit. I didn't check and just had the shop do both.
