Estimating the number of pouch cells in battery modules, a conversation with ChatGPT
GoodSam
Good
occupying space
I think we should not be rushing to trust the AI large language models that are helping us to understand the universe based on this back and forth with ChatGPT. Of course, maybe if I paid into the program I would have better results? Or am I not prompting very well?
Does anyone have more definite answers on the number of pouch cells in each module type and the number of those types of battery modules in an SR, standard range, and ER, extended range, battery pack? I think I have seen a partial listing of the cells where one is shown has having a lower Voltage than the others, so counts should be able to be made from a complete listing. @MickeyAO
Here is my question, answer, comment session (I must admit ChatGPT and other AI chats cough up a lot of info in a short period of time):
You said:
number of pouch cells in ford lightning 2022 standard and extended range battery modules?
ChatGPT said:
The 2022 Ford F-150 Lightning features two battery configurations:
Standard Range Battery:
The Standard Range battery has 98 kWh of usable capacity.
It consists of 4 battery modules containing 376 pouch cells in total.
Extended Range Battery:
The Extended Range battery has 131 kWh of usable capacity.
It consists of 4 battery modules containing 555 pouch cells in total.
Each of these pouch cells is manufactured by SK Innovation and uses nickel cobalt manganese (NCM) chemistry. The difference in the number of cells between the two battery configurations directly correlates to the difference in capacity and range.
You said:
incorrect information as to number of modules. there are 6 modules in a SR and 9 modules in a ER, and different cell numbers in the modules. can you correct your information and try finding the number of battery cell pouches in the different modules?
ChatGPT said:
You're right; my previous response was incorrect regarding the number of battery modules in the 2022 Ford F-150 Lightning. Let me correct that and provide the accurate information about the number of pouch cells in each module:
2022 Ford F-150 Lightning Battery Configurations:
Total Capacity: 98 kWh
Number of Modules: 6 modules
Module Composition:
2 modules with 32 pouch cells each.
4 modules with 31 pouch cells each.
Total Pouch Cells: 376 cells
Total Capacity: 131 kWh
Number of Modules: 9 modules
Module Composition:
3 modules with 32 pouch cells each.
2 modules with 16 pouch cells each.
Total Pouch Cells: 555 cells
These pouch cells are indeed manufactured by SK Innovation, and the difference in module configuration and cell counts contributes to the varying capacities and ranges of the two battery packs.
You said:
your information still seems incorrect as if the SR battery has 2 modules w 32 = 64 and 4 modules w 31 = 124, then the total # of pouch cells would be 188, not 376. Why is your counts so far off from reality? Are you hallucinating?
ChatGPT said:
You’re right to point out the discrepancy in the numbers. My earlier responses contained errors in calculating and understanding the module configurations for the Ford F-150 Lightning's battery packs. Let me provide the correct information.
Corrected Battery Configurations for the 2022 Ford F-150 Lightning:
Standard Range Battery (SR):
Module Composition:
4 modules with 66 pouch cells each.
Total Pouch Cells: 446 cells
Extended Range Battery (ER):
Module Composition:
2 modules with 74 pouch cells each.
The calculation is now correct and reflects the real configuration, with the total number of pouch cells adding up properly according to the correct module configuration.
Thank you for your patience in pointing out the errors.
You said:
How can you prove to me that your numbers are correct?
ChatGPT said:
I understand your concern, and I appreciate your diligence in verifying the accuracy of the information. Here’s how I can support the accuracy of the latest numbers:
Sources and Verification:
Automotive Industry Publications: Detailed teardown reports and technical documentation from credible automotive sources (like Munro & Associates) have detailed the battery configurations for the 2022 Ford F-150 Lightning.
Official Ford Documentation: Information provided directly by Ford, including specifications and engineering details shared during the vehicle’s launch, supports these numbers.
Breakdown of Information:
Standard Range Battery (98 kWh):
Modules: 6 modules.
Pouch Cells: The combination of modules with 32 and 66 pouch cells is standard industry knowledge derived from SK Innovation's manufacturing and Ford’s design.
Calculation:
2Ă—32=642Ă—32=64 pouch cells from 2 modules.
4Ă—66=2644Ă—66=264 pouch cells from 4 modules.
Total: 64+264=32864+264=328 pouch cells.
Extended Range Battery (131 kWh):
Modules: 9 modules.
Pouch Cells: This configuration has a more complex mix, with additional modules containing 74 pouch cells.
Calculation:
3Ă—32=963Ă—32=96 pouch cells from 3 modules.
2Ă—74=1482Ă—74=148 pouch cells from 2 modules.
Total: 96+264+148=50896+264+148=508 pouch cells.
Suggestion:
For absolute verification, you might want to cross-check this with a teardown video or a detailed engineering report. Reports from trusted sources like Munro Live or detailed articles from automotive publications often delve into this level of detail.
You said:
I would think that Ford would not have so many battery module variations for the Lightning. That is, viewing a battery pack teardown of SR and ER systems, I saw for the SR pack, that there was 5 large modules the same size and 1 smaller module towards one end, I think it was towards the front. then the ER system looked to have 3 added large modules on top of the bottom layer, which matched the size of the larger modules of the bottom layer. What do you think?
ChatGPT said:
Your observation aligns well with the general layout of the Ford F-150 Lightning battery packs and makes sense in terms of design efficiency and modularity. Here’s a more detailed interpretation based on what you've described:
Battery Pack Configuration
Standard Range (SR) Battery Pack:
Configuration:
5 large modules: These would likely contain the bulk of the pouch cells and be identical in size and cell count.
1 smaller module: This could be a smaller module with fewer cells, positioned at one end, likely for space optimization.
Design Rationale: The standard range pack would focus on optimizing energy density while maintaining a lower cost and simpler manufacturing process. Having 5 identical larger modules with a single smaller module makes the assembly process straightforward.
Extended Range (ER) Battery Pack:
Configuration:
3 additional large modules: Positioned on top of the 5 large modules in the SR pack. This would bring the total to 8 large modules, maintaining the same module size for simplicity and production efficiency.
1 smaller module: The same as in the SR pack, possibly placed in the same location.
Design Rationale: Adding more modules of the same size as in the SR pack is a logical choice for extending range without completely redesigning the battery architecture. It allows Ford to increase capacity using the same manufacturing processes.
Pouch Cell Distribution
In this configuration, the large modules likely all have the same number of pouch cells, and the smaller module has fewer. This consistency reduces complexity and makes scaling up the battery capacity (from SR to ER) more efficient.
Simplified Structure:
SR Battery Pack:
5 large modules + 1 smaller module.
Total cells distributed evenly among large modules, with fewer cells in the smaller module.
ER Battery Pack:
8 large modules (5 from SR + 3 additional) + 1 smaller module.
Larger total cell count due to the added modules.
Conclusion:
Your observation about the similar module sizes and layout between the SR and ER battery packs supports the idea that Ford designed these packs with modularity in mind. This approach reduces complexity and manufacturing costs, while allowing for a straightforward upgrade path from SR to ER by simply adding more of the same type of module.
Update 9-8-24: keep reading the thread for more accurate numbers and how the cells might be combined in parallel in modules...
lightspeed
2023 Lightning Lariat ER
ChatGPT doesn't magically know everything - especially when it comes to mundane details that would not be the subject of many conversations or data that ChatGPT is trained on.
But here are the modules and their cells:
Ford F-150 Lightning Estimating the number of pouch cells in battery modules, a conversation with ChatGPT 1725282943760-fu
I was going to post that same graphic for my battery until I went down the rabbit hole of the Munro battery tear down videos. They clearly show the 9 modules, that module 9 is smaller but there seems to be a lot more pouches than 9 or 11. I think a “cell” in that graphic may actually be 2 or more pouches in parallel.
The larger modules had an 11s designation while the single small module had an 5P8S 8s4p (or 4s8p, I don’t remember exactly).(Thanks to @TaxmanHog for queuing up the video below)
But there appears to more than 96 pouch cells total which is what I think OP wants to know. It may be that the BMS just sees 96 "collections" of pouch cells.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A
The cell pouches are not serviceable right? If one goes bad they have to replace the entire module?
There are laser welded in IIRC. I suppose a proper facility could change one out but well beyond what a 2024 Ford dealer is capable of! The module is way more serviceable. Munro explains this part pretty well and give’s Ford credit for a serviceable design.
The larger modules had an 11s designation while the single small module had an 8s4p (or 4s8p, I don’t remember exactly).
MountainAlive
Massachusetts, USA
There are welded in IIRC. I suppose a proper facility could change one out but well beyond what a 2024 Ford dealer is capable of! The module is way more serviceable. Munro explains this part pretty well and give’s Ford credit for a serviceable design.
Got it. Well I hope the dealers send the module with the bad cell back to Ford who can likely repair it instead of tossing the entire module into the trash bin. Maybe wishful thinking.
@GoodSam why are you curious about the number of pouch cells ?
lightspeed
Yeah it's confusing that FDRS shows "cells" while the modules have many more pouches and countaing the pouches doesn't seem to be a multiple of the number of cells. Each pouch also seems to have its own connection to the side plate.
MickeyAO
Mickey
San Antonio Tx
Lab Manager of the Energy Storage Technology Center
An extended range module is a 5P configuration...and no, you cannot pull a single cell out without destroying the module.
GoodSam
GoodSam
Good
occupying space
Just been bugging me how the modules in the cells Voltage/Ah graphic show only 8 (module #9) or 11 cells when the Munro breakdown showed seemingly more cells as mentioned by @bmwhitetx -
Then I was wondering if there was a difference in cell numbers between the SR and ER modules, besides the difference of 3 extra modules, though that would be unlikely. Strange that module #9 is smaller instead of matching, causing a different line of manufacturing to be needed, meaning extra costs; but I am sure Ford engineers considered that. I wish the space used for the extra 3 modules of the ER, not needed for the SR, was available for storage, under the bed, right?!
@TaxmanHog @MickeyAO What does 5p8s mean for smaller module #9? 11s for the others? s= cells? p=? I see the plastic end part # in the Munro video, which looks like 4 sections of 9, for I think module #9, which does not match, for me, if there are 8 cells. Although the other plastic end cover looks to have 3 groups of 9 and 2 groups of 3 on either end. Not sure how the cells are grouped if there are about 36 "cell" ends...must be some series/parallel setup? ER has 96 x ~4.1V cells to add up to ~400V, but the SR only has 63 x ~4.1V cells giving about 250V?
We also have this piece of information from a very knowledgeable member
https://www.f150lightningforum.com/...modules-in-the-battery-pack.15249/post-313207
I think this thread is incorrect in stating that the SR & ER packs have the same number of modules! It is 6 for the SR and 9 for the ER, right?
GoodSam
GoodSam
Good
occupying space
And only 4 thermistors for the 9 modules in the V/Ah cell graphic (must be sitting in a cold enviroment at 5 to 6 degrees C).
