Ige
- Nov 14, 2023
- Northern California
- Lariat Lariat ER
My FCSP has an amber solid light on the right and flashing blue in the middle when charging. The manual notes that this means "charging at a reduced rate". Some points:
-It has worked wonderfully for about a year
-I have the internal dial set at 5 (48 amps) 11i-sh kw
-the reduced rate is 6 kw
-the reduced rate started about 2 weeks ago
-it happens at any state of charge (not only when battery is near full)
-I have never been able to connect the FCSP to my internet despite 4 hours of failed attempts when it was initially installed
-it charges without any problems at public charging stations at full rates
-I've tried flipping the breaker off for 5 minutes to reset it without avail
My plan is to remove the cover and reset the FCSP. I will also try to connect it again to the internet and see if the app has any solutions. If those two things fail I'll call the number on the FCSP manual to get some support - but, I have found that these phone conversations with Ford haven't usually been helpful when I've called for different reasons in the past. Perhaps you folks have had better luck with Ford on the phone?
If you forum friends have any suggestions, I'll be quite grateful.
Thanks!
IGE
Thanks!
IGE
