Strange buzzing sound / “accessories” battery drain
thequackenbush
Ryan
Marketing
My lightning within the last week or so suddenly has a buzz sound, similar to a neon light, that I can hear
it happens regardless of whether it’s being charged, sitting idle, or driving. Often, but not always.
I also see a significant portion of my battery per drive is being allocated to “accessories.” I turn off pro power when not being used to maximize range. I don’t have anything else being used.
Anyone else running into this?
the attached video was a bit after driving sitting in my driveway. It was a warm sunny day.
Ford F-150 Lightning Strange buzzing sound / “accessories” battery drain IMG_0126
Ford Motor Company
Official Ford Account
Ford
F-150
Hi Ryan, we’d like to investigate the noise from your Lightning. Please send us a private message with your VIN and local Ford Dealer. Thanks!
Looking forward to a follow-up of what your local technician finds, those are not normal sounds IMHO.
ctuan13
Chuck
Pittsburgh, PA
The base buzz is actually a sound I'm very familiar with. It's the coolant pumps. However the weird actuator type noise, is very odd...
Maybe the diverter valve [3] is stuck trying to cycling between PTC to battery or loop back to cabin/PTC.
Ford F-150 Lightning Strange buzzing sound / “accessories” battery drain 1729248064931-je
thequackenbush
thequackenbush
Ryan
Marketing
Taxman is this gonna blow up
Or something? I have to drive into Boston next week, no time to bring it to a mechanic
I don't know for certain, but it may impact range.
I think I've only read of one or two other members having an issue with the diverter valve.
thequackenbush
thequackenbush
Ryan
Marketing
Am at the dealership now having their master techs look into the problem; will report back
thequackenbush
thequackenbush
Ryan
Marketing
Techs say: “scan vehicle doc’s, none present. Test drove vehicle, no abnormal noises heard. Traction motors are able to be heard when driving and coasting to a stop which is normal. When stopped or plugged in, coolant pumps are activated to keep the battery at a specific temperature and can be heard running which is normal. Unable to verify concerns at this time” so I have no idea
I guess all you can do is drive it until something breaks, at least your initial concern is recorded, good luck in the meantime!
