XLT ER
Once again Oct '23 build XLT ER... Installed around 4 pm today.
Some things I noticed. Two updates ago the software update screen started loading extra fast in comparison to prior that update... ( You know when you press the update button and it shows what the last update was.)
Right before the ...1.0 version of this update, the charging station app/map would give a connection error but when I closed that prompt it was still showing available charging places BUT it was not showing any of the fast DC sites that I knew were within a mile of my location. The ...1.0 version of this removed the connection error pop up and everything is correct for the location where I am at, either when driving or stopped. I know the last update was to allow you to search while driving.
Also two software updates ago the download bell icon at the top of the screen has disappeared. And after the ....1.0 version of this update that update now button has completely disappeared off the software update screen.
Ford F-150 Lightning OTA Software Update - 10.1.1 - Enhanced Conn & Power Management adds karaoke app 1000012930
mrau
23 Lariat⚡ER
Just got 10.1.1 today as well. Three days after 10.1.0.
Oct 2023 build- Lariat ER. (Must be on the same schedule as @Bitterbrush)
jeff_h
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
Same here, Oct 23 build XLT ER, got this update today.
Have others had their charge routines upended when a software update occurs? It happened when I got the 6.8, 6.14 (whatever update types those were), and a few days ago with the 10.1.0, and today with the 10.1.1: when I pull into the garage and plug in, the charger (not a Ford charger, it's a Clipper Creek 32A that I've had for about 4 years, it doesn't have wifi connection etc) starts for about 2 seconds then stops... and that's how I know I got a software update. I pull up the app and the status is "waiting to charge" and a couple times hitting start on the app will start it, and other times I have to pull the charge cord handle out and plug it back in a few times in concert with clicking the start button on the app, and finally it will start charging... and then after that things are fine.
I guess something like that might be expected if the truck was set for delayed charging of some sort, but my electricity costs the same 24/7 so it has NEVER had any charging schedule set up.
It's frustrating that this has now occurred several times, just wondering if it also happens to others?
It's not unusual for the charging and departure time schemes to get screwed up after an OTA has posted, I'm reading of several posts over the past week on that theme.
You could try deleting them and building a fresh set of rules.
jeff_h
WV
That's the odd thing - I don't have any departure times set, never have had any set... yet the updates revert the behavior to "waiting to charge" for unknown reason.
That is the message for when there is a time restricted charging scheme set on your truck and the EVSE cord is plugged in with energy available but not currently flowing due to the time restriction.
If you have charging schemes delete everything and rebuild the rules.
