DIEProphezeiung
Charlie
Birmingham
23 Lightning XLT ER
Hey, I just want to say thanks for all the hard work on this everyone! I got my Comma3x installed and running the latest staging version of Bluepilot, and I extended my harness to the mirror. I went for my first few drives today, and so far, so good!
I'm printing the 8-degree window mount now and will most likely swap to the sliding version @Ajzride is using for easy, quick removal in the summer.
Looking forward to future updates!
Mike G
N. AL, USA
Bluepilot or Sunnypilot? Trying to figure out the differences, and the DL links.
I'm on the Sunnypilot discord but....
Ajzride
Alan
Houston
Eng
bit.ly/bp-stable
bit.ly/bp-staging
bp is just sp with ford specific enhancements.
FLSpartan04
Daryl
23 F150 Lightning XLT ER
I’ve not been following as closely recently. Is there a simpler harness solution yet, or does it still require soldering?
Ajzride
Alan
Houston
Eng
there is an extension you can make, only need to crimp, no solder
DIEProphezeiung
Charlie
Birmingham
23 Lightning XLT ER
I ended up cutting and soldering in a 12 conductor extension. Didn't want to wait for the pins that are on backorder.
On a side note, I had a longer drive today, about 50 miles, and I noticed about halfway through that I had not connected the OBD2 plug. Thing is the Comma booted up and seemed to work normally without power from the OBD2 port.
When I realized it wasn't plugged in, I plugged it in while I the Comma was actively driving and didn't seem to see any difference.
Are there certain features or services that will not work with no power from the OBD2 port? Seems like it was working as intended without it.
Ajzride
Alan
Houston
Eng
OBD just keeps device powered between drives. if you don’t mind waiting on it to boot every time you can omit it.
FLSpartan04
Daryl
Awesome. Decided to jump on the sale and finally ordered the comma ai. Luckily, I planned to do this sooner and had added the connector stuff to a mouser order earlier this year. So I just had to order the Amazon items to make my extension. I’m excited to get this going. Would have been nice to have for my road trip to MI or northern GA.
Ajzride
Alan
Houston
Eng
check that you have the connectors for the new style harness. Comma redesigned about 2 months ago. Pins are the same but connector is different.
FLSpartan04
Daryl
Good to know. I looked up your video on the extension and linked through to all the part numbers and checked them against what I had. Interestingly, I bought the stuff for the original version of the harness where the Q4 harness was modified. Is there a better source to verify I have the correct parts?
Ajzride
Alan
Houston
Eng
Ajzride
Alan
Houston
Eng
PSA: unfortunately, we were able to confirm the 2024+ Lightning does not work with comma
Persius25
Nick Buddemeyer
2024 Ford 150 lightning lariat
Have been following this and just bought a 24' lariat. Do we know why it doesn't work with a 24? Was hoping to add this.
Ajzride
Alan
Houston
Eng
Encrypted canbus.
