Factory!Are those factory offset wheels or did you add a spacer?
NoDid you have to cut the front crash bars out with just the 2" level?
I don't have for scan, unfortunately.You can change the tire size in Forscan if you use it. Then it will be exact. I’m doing the same lift and put larger tires and well - should have it back next week! The tires are already on but waiting for the lift…
no, yes, https://www.roughcountry.com/ford-lightning-leveling-lift-kit-52000.html,Did you change out anything on the shocks? or just add the rubber lifts? Which 2-inch rough country lift did you purchase? I want to make sure I get the right one. Thanks!!
yeah there is some people reporting no rubbing on 35s but I decided to go the safer bet and go a bit smaller. For two reasons rubbing and range not sure the difference in range if I went even bigger than what I have.he says no rubbing. I did
35" on my old '21 PowerBoost, had no rubbing.
Correct!Looks like they are 18” from the ICE XLT
It's all about offset.... I have a 3" lift with +1mm offset and same tire size, and I had to trim the lower plastic, and a bit of the backside of the bumper, and just a bit on the crash bars too... Nothing dramatic, but definitely rubs with a different offset
