FLSpartan04
Daryl
23 F150 Lightning XLT ER
check that you have the connectors for the new style harness. Comma redesigned about 2 months ago. Pins are the same but connector is different.
Just ordered the new white connectors. I think everything else is the same (hopefully).
FLSpartan04
Daryl
OBD just keeps device powered between drives. if you donā€™t mind waiting on it to boot every time you can omit it.
I just got mine plugged in finally, doesnā€™t seem to boot without the OBD plugged in. No blue led or anything. It does boot with the OBD plugged. I wonder if they made a change?
Ajzride
Alan
Houston
Eng
No. if itā€™s not booting when the truck cranks then itā€™s not getting 12v through the USB cable, which is an issue. It wonā€™t be able to detect when the vehicle starts a drive.
FLSpartan04
Daryl
Interesting. This is the same guy from the discord in a panic (which you probably deduced by now). I wonder if something is wrong with my Q4 or comma? This test was done without the extension, so only comma components. This may tie into my other problems. Iā€™ll take some videos when I get time to play with it and share them on the Discord. Thanks as always!
FLSpartan04
Daryl
Turns out I stink at crimping those tiny pins. It I keep trying, Iā€™m going to use them al up, and they are on back order. Anyone willing to make up the extension harness for me? Iā€™ll ship all my materials, and pay for your time. Also will throw in a set of tow hook covers! šŸ˜‰
