Persius25
Well that's extremely disappointing. Thank you for everything you've done with this project!Encrypted canbus.
Just ordered the new white connectors. I think everything else is the same (hopefully).check that you have the connectors for the new style harness. Comma redesigned about 2 months ago. Pins are the same but connector is different.
I just got mine plugged in finally, doesnāt seem to boot without the OBD plugged in. No blue led or anything. It does boot with the OBD plugged. I wonder if they made a change?OBD just keeps device powered between drives. if you donāt mind waiting on it to boot every time you can omit it.
No. if itās not booting when the truck cranks then itās not getting 12v through the USB cable, which is an issue. It wonāt be able to detect when the vehicle starts a drive.I just got mine plugged in finally, doesnāt seem to boot without the OBD plugged in. No blue led or anything. It does boot with the OBD plugged. I wonder if they made a change?
Interesting. This is the same guy from the discord in a panic (which you probably deduced by now). I wonder if something is wrong with my Q4 or comma? This test was done without the extension, so only comma components. This may tie into my other problems. Iāll take some videos when I get time to play with it and share them on the Discord. Thanks as always!No. if itās not booting when the truck cranks then itās not getting 12v through the USB cable, which is an issue. It wonāt be able to detect when the vehicle starts a drive.
