Is passive entry the only option if I want all doors to unlock?
tallskydiver
Zeke
2024 F150 Lightning Flash
I do like the WAL (Walk away lock) feature, however.. I've had my 2024 Flash for only a few weeks and there has been MANY times where I've been loading/ unloading the truck (presents or tools in the rear doors).. and I when I walk back to the house for another load, and walk back to the truck/ need to open the back doors, I have to find the FOB, and press the unlock key. The dumbed down version I suppose is simply to leave the door open while I am making trips to and fro. :)
I'd prefer a forscan resolution.. or rather I was hoping to find one where I could modify the unlock feature to unlock all doors when Walking back up to the truck.
The only thing I can find is another post mentioning Passive entry.. which requires a bit more than I was wanting to do.
So, is there any other way to modify the Lighting where it will auto unlock all doors when walking up?
astrand1
Alex
Studio truck driver
Unfortunately I don’t think that’s a thing. You have to put your hand into the handle to unlock truck. If somehow I’m wrong hopefully someone will correct.
ryun
Earth
If you look in settings there should be a setting for the key fob where clicking the button once opens all doors rather than opening just the driver side (this is the default).
It's possible changing this setting to unlock all doors will work for you. I don't have the features you have to confirm, but I did notice something interesting about changing this setting: the keypad on the door unlocks all doors now. Whereas before it only unlocked the drivers side. So the setting isn't just for the key fob.
ryun
Earth
Or it could just be this:
Ford F-150 Lightning Is passive entry the only option if I want all doors to unlock? IMG_0878
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
I have a flash too. I believe there is a setting on the screen that you can allow front or front and rear doors to unlock with WAW function.
By the way, I love the WAW lock / unlock feature in the truck. I use constantly with my jobs going in and out of the cab and bed.
I keep it set for front only. But either use the fob to open the rear doors or push the front interior door switch when rear door access is required.
Rick
luebri
Neenah, WI
I'll never use Walk Away Lock if they dont give you a whitelist option based on location. (e.g. dont lock my damn vehicle if its in my garage!)
ZSC100
Zach
Tulsa, OK
Electrical Engineer
So, I am confused, with Flash trim you have WAL and Unlock, but not passive entry as in the capacitive sensor door handles?
