Ford Perimeter Plus Security System
astrand1
Alex
Studio truck driver
Well part wise it’s pretty cheap so you’re not going to get hurt buying it. To pop the console down you want to use a trim tool and gently pry down on the 2 rear corners. It will give you enough room to get your fingers in there and just start at rear and move forward and it will pop down. Just don’t pry at front. Once down there should be a blue box there. It’s a dummy box. Just empty but the small wiring harness will be plugged into it.
Blochead21
PA
Black 22 XLT 311pkg
What does adding this do for the truck? Just like a shock sensor?
XENOILPHOBE
DC Swamp
2024 F-150 Lightning Platinum, 2024 Tesla Model X Plaid, 2024 Model Y AWD
Retired Army
astrand1
Alex
Studio truck driver
Yes sir. Works as designed.
Jim Lewis
Jim Lewis
San Antonio, TX
And after the FORScan edits, controls at least to turn it on and off show up somewhere in the SYNC screen settings? The reason for turning it off might be leaving your wife or your dog locked in the truck while you pop into a store to get something. (I anticipate possible jokes about the last sentence! 😃 )
