Frunk light bar alignment
Maineiac12
Iowa
Is the only way to adjust the light bar alignment by turning those rubber cap screws on either side of the frunk?
My light bar isn’t flush and I’m trying to get it aligned without going to the dealer. Is it possible?
watts/up
23 Pro SR
You may want to check out this thread on adding the light bar to Pro trims. There may be some adjustment of the light bar itself (not the hood) via the 5 M6 bolts.
Depending on what is out of alignment, even the dealer may not be able to help you. There is no adjustment on the lightbar itself. You have to adjust the whole frunk.
Do you have a picture of what is out of alignment?
BennyTheBeaver
The Lightbar on my XLT was low. I adjusted it via the bolts the above poster said when I added the light up emblem. Now it's perfectly aligned.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
On my truck I had to adjust the rubber hood stops a little but I also had to adjust one of the headlights. It wasn’t too hard. See this video:
Maineiac12
Iowa
My frunk and middle light bar are higher than the light bar on the headlights. I’ve tightened up the rubber stoppers on either side and it looks better now, but I still think my passenger side is a bit higher.
Before:
Ford F-150 Lightning Frunk light bar alignment IMG_5450
After:
Ford F-150 Lightning Frunk light bar alignment IMG_5586
