Memory Settings Don’t Work After Using PAAK Remote Functions
Caliber357x
‘23 Lightning Platinum
Hi there - this is a very small issue/quirk, but I figured I would ask in case anyone has had this problem and found a solution. I have a ‘23 Platinum (took delivery new in 10/24, only owner) and use PAAK with iOS. If I use the app to unlock the vehicle or precondition before a trip, when I get in the vehicle and step on the brake and press the power button, none of the memory functions work automatically (mirrors, seats, pedals, steering column). If I enter the vehicle with the phone in my pocket and unlock either by door handle or the keypad, the memory settings function just as one expects. Again, I know that this isn’t a big deal, as I just press the Memory 1 button after I start the truck, but I can’t figure out a reason why this occurs.
This has happened since day 1, and I’m currently on software update 10.1.1 (and patiently awaiting BC 1.4…) so I thought maybe one of the many updates I received might resolve the issue, but no dice. Any help is appreciated in advance - thanks!
Jesse-Infotainment
2024 F150 Lightning Flash
DO you have profiles assigned?
When I do remote start, the truck starts up as Guest and not my profile. I assume its because it doesn't know who started the truck via the FP App.
Yep!
The workaround is to set the guest profile up exactly as your own.
Caliber357x
Caliber357x
Well, that was the problem - I had a fob assigned to my profile, but I didn’t have my phone assigned - added the phone and tested, and all is right with the world. Thank you all!
Jesse-Infotainment
Good.
