Stay in SPORT when truck turned off
Yes it does, but when you use the brake pedal, the truck decides how much and when the friction braking will be used. Much of this depends on how much pressure you apply and also what speed the vehicle is going (i.e. the blend for the pressure applied varies a bit with speed).
The vehicle will use as much regen as possible, but there is a point where friction must be used. At about 2 or so mph, it loses its effectiveness and must use friction. When the vehicle gives you a brake score of 100%, it means that all the regen that possibly could be used to stop was used. A score of less means that some friction braking was used that could have been done with regen if it weren't for pressing too hard on the brake pedal. Now, if you did so because the car in front of you suddenly hit the brakes, then the loss of regen is better than what would have happened if you hit them trying to get every last drop of regen ort of the stop.
Using one-pedal mode and keeping your foot off the brake pedal will give a score of 100% on every stop. I don't use Sport Mode, but my understanding is that it provides a similar benefit of regen.
In my observation, when using the brake pedal on the Lightning, I have a better chance of getting a 100% score than I do with my Focus Electric. On the FFE, you have to be extremely light on the brake pedal to get 100%. So many times I swear I was really light only to get a score of 96 to 99. The Lightning seems easier to get 100%.
Well, yeah, you CAN cause the mechanical brakes to engage. However the amount of braking you need to apply is FAR FAR above and beyond what Sport mode provides.
So yes, you can cause the mechanical brakes to engage, but that is because you are trying to slow faster than any mode and any regen could provide otherwise. However my comment was only made since he said regen, and just trying to ensure that folks know that you don't get MORE regenerative braking in Sport, or a difference between that and applying the brake pedal.
CRAIGC540
Craig
Moreno valley
Technician
I like the Sport setting for the dash "lighting".
Much sharper contrast is easier on this old guys eyes.
I'm the opposite, I like blue and purple colors. I wish we could select a color and it stayed regardless of what mode your in, also change the indirect lighting with the dash color.
Phil D
phil
2024 Ford F150 Lightning Flash
Law Enforcement
Sorry. I need some clarification.
If I use SPORT and ONE PEDAL I will gain energy via regenerative braking and less use of brakes.
If I use SPORT and ONE PEDAL *OFF* I will NOT gain energy via regenerative braking and I will most likely need to replace brake pads sooner.
Is that correct?
Whammy Bar
Is that correct?
Depends how hard you press the brakes. It will regen up to a point, but if you are feeling too "sporty" the friction brakes will kick in as well.
Set your driver display so you can see when you are using regen and calibrate your foot accordingly.
John Becker
Cincinnati
2023 F150 Light'g Lariat SR, '18 Audi S5 Cabriolet
Is that correct?
No. Sport is simply more aggressive. Total regen is not substantially different regardless of driving mode or 1PD/2PD.
The choices are much more about driver preference than total regen.
Sport 2PD is simply more aggressive than Normal 2PD. Total regen is not substantially different.
Is that correct?
In the lightning pushing the brake pedal does not immediately engage the mechanical brakes, instead the electric motors slow the truck through regenerative braking, or regen. Sport, tow haul, and 1pd drive just varying how much regen is automatically performed.
In the end it is the same. The only difference is that with the brake pedal it is possible to slow hard enough that regen alone does not have enough capability to slow the vehicle as much as you are demanding, and so the computer will automatically apply the mechanical brakes to slow you faster. In any of the modes there is not enough slowing of the vehicle to engage the mechanical brakes, they will only ever use regen*
*except in specific conditions
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Perhaps we are talking two different issues.
One pedal driving applies the max regen possible every time you completely release the acceleration pedal, so you learn to feather the skinny pedal. In most cases I never apply the friction brakes. When stopped you feel the friction brakes applied to hold you tight at the stop sign.
One-pedal can be used in any of the driving modes, and the slowing effects of max regen during all driving modes are the same.
John Becker
Cincinnati
We are in agreement. Except I'm not sure about "all" driving modes. Certainly Normal and Sport.
