Turn Signal on Camera while towing - Drive modes gone
Martin
2023 Ford Lightning, 2021 Mustang Mach-E GTPE
Hi All,
Programmed the APIM and IPMA on my 23 lariat ER last week to enable the turn signal cameras while towing and it works great, expect for one problem. I noticed Saturday that the drive modes screen in the menu is gone. Something with the configuration of the 2 modules turns it off. Anyone have any ideas or has enabled this without loosing the drive mode screen.
Changes made:
APIM (7D0-02-03) to XXXX-X8XX-XX-- (have not tried C in the APIM yet)
IPMA (706-01-02) to 3XXX-XXXX-XX
I can revert back to ABD but I really like the option.
Thanks everyone.
2023 F150 Lightning Lariat ER
Tow tech package
NOT max tow
Fully updated (12/23/24 with FDRS)
Ford F-150 Lightning Turn Signal on Camera while towing - Drive modes gone menu
Check this setting:
Ford F-150 Lightning Turn Signal on Camera while towing - Drive modes gone 1736206260361-u9
Changes made:
For 7D0-02-03, based on Livinup's spreadsheet, you want to add 8 to the previous value to enable TSV. What value did you have there before?
Looking at Lightning As-Builts, Pro XLT had 0 while Lariat have 4. So you would want a "C".
Edit: If you changed it from a 4 to an 8 you would have disabled Controls Tab.
Ford F-150 Lightning Turn Signal on Camera while towing - Drive modes gone 1736207206090-vu
Martin Rebuilds
Martin
I will check what value I had before and play with the values in the chart. Report back soon but its 9° here today so maybe later than sooner.
wingfiry
Ryan
Cleveland, TN
2023 Lightning Lariat ER
using "C" in the APIM (7D0-02-03) to XXXX-XCXX-XX Does indeed keep the Controls menu, but I haven't tried a trailer plugged in yet to verify that the turn cameras are still active.
The config to the APIM only adds the button to the touchscreen. You would need to also make a config change to the IPMA to enable the feature itself. However, the IPMA must be at certain level in terms of the software on it for this to work.
wingfiry
Ryan
Cleveland, TN
I had previously made the IPMA config change, but also used 8 instead of C in APIM.
