RAM cancels REV long range model
Smart decision, let the hybrid take on the challenges of high load and long distances, leaving the L model for mall crawling, local lumber yard and grocery getting.
I never really understood the goals Ram was going for here. If you have a hybrid you don't need massive battery range, that's the point of the hybrid. 100 miles or so is all you need on the battery, that will cover 95% of most of the drives people make.
Frankly, this sounds like a good move
Altivec
Exactly. I own a plug in hybrid car. If you have that size of battery, the engine will never be used which is bad for the engine and fuel. You are also carrying the extra weight of that engine and fuel all the time.
I am not even a big supporter of plug-in hybrids either. I got one because I wanted an EV but was too scared of range anxiety and thought it would be the best of both worlds. I ended up using it as EV almost all the time, which caused the issues I mentioned above. Now that its getting older, problems are arising due to the complexity of having both systems, one hardly used with dried up seals, and the other one with a battery that went through a lot of cycles because its small. Double the problems, double the expenses, and few that will work on them. I always recommend choosing either EV or gas.
