Range Projection stuck on towing.
dtomlin
Cornelia GA
Ford Lightning
I towed a trailer twice last week. Since then my truck and my mile range projections have been based on towing at 1.2 M/Kwh. Is there a way to change that or will it eventually reflect my current driving range?
Go into the towing screen and select no trailer. Or hook the trailer back up and unplug it when the truck is on so it knows the trailer has been disconnected.
dtomlin
Cornelia GA
Ford Lightning
I selected no trailer and when I turn it on, it still flashes the screen about trailer attached. I will try the disconnect while the truck is on. thanks
Probably goes without saying, but don’t hook up something like this:
Ford F-150 Lightning Range Projection stuck on towing. IMG_1120
Ry2023
Rick
Pa
2023 f150 lightning
I have the same problem . When ever I tow and it goes into the low mileage warning( which everything turns yellow) unhooking, or turning off tow mode, does not bring the mileage back to non-towing. You have to go in and reset driving history. That’s what works for me. Hope this helps.
dtomlin
Cornelia GA
Ford Lightning
Resetting my driving history did not solve the problem.
Ry2023
Rick
Pa
2023 f150 lightning
Hmm… try this ….where did you reset it at? Under charging? If so, there is another way to reset it… i think In settings … try reseting it there… and see if that works…. Im going to go to the truck to see where it was… because I have faint memory of having that problem as well…
Ry2023
Rick
Pa
2023 f150 lightning
Ok so hit the truck icon… go in to vehicle and reset ev driving history there and let me know if it works
