FordPass NOT displaying the current state of charge and unable to set to 100%
LSUT1GER
Slidell, LA
Computer Engineer
My FordPass app on my Samsung S25 Ultra will not display the current state charge or allow me to set it to 100%. The version of the FordPass app is 5.11.0. I'm able to remote start my 2023 F150 Lightning Lariat ER, remote open/close the frunk/tailgate, etc plus my phone is connected as 'Phone As a Key". Below are screenshots from my phone and pictures that I took to document what's going on. This is my 2nd Ford Lightning Lariat. The first one was a brand new 23' Lariat SR and I put 36,000 miles in one year then traded it in for a brand new 23' Lariat ER (which now has over 20,000 miles). I have a Emporia Level 2 EV Charger installed in my garage and I have been using it 99% of the time charging both trucks. This has never happen before.
Charge Information on my FordPass
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739018474551-i2
State of Charge in my Lightning
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739018569518-hr
I had to go into my truck to set it to charge to 100%.
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739018628899-js
Currently charging to 100%
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739018691528-hl
FordPass App Version - 5.11.0 - Last updated on 1/20/2025
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739019555662-cx
I even cleared the FordPass App cache which still didn't help and I rebooted & shut off my phone.
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739019738741-03
Here's my phone. Maybe it's a Samsung One UI version 7.0 or Android 15 issue.
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739019881508-2k
S25 Ultra software specs.
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739020043279-st
Any help or helpful information would be very much appreciated. Thanks!
150Flash
2024 Ford F150 Lightning Flash
I had the same issue of not displaying the expected completed charge time with my iPhone this past week. Downloading FordPass version 5.12 corrected it.
LSUT1GER
LSUT1GER
Slidell, LA
Computer Engineer
I'm on adroid and there not any updates available for the FordPass app as I yet but I will keep checking. Thanks for the response.
This might be a sign of back end issues on the Ford cloud or the trucks TCU is not phoning home to the cloud, note that some of the functions which are working are doing so via the bluetooth comms.
Give it a few more hours and the server might come back if that's the issue.
BTW, my experiences with similar symptoms earlier this week:
Services for remote climate start & charge monitoring failed today
LSUT1GER
LSUT1GER
Slidell, LA
Computer Engineer
Thanks for the response. That makes sense since the bluetooth stuff works but the cloud stuff doesn't. This Lightning forum is a wealth of knowledge and I appreciate all the Lightning owners who share their experience and knowledge.
LSUT1GER
LSUT1GER
Slidell, LA
Computer Engineer
State of charge is still not updating and it's going on 3 full days. I've rebooted, shut down (both phone and truck multiple times), and cleared the FordPass app cache on my android Samsung S25 Ultra (twice). I'm taking to the dealing for a that UPPER CONTROL ARM BALL JOINT NUT REPLACEMENT recall tomorrow and maybe the dealer can do something. Is any other android users having this same issue?
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739193365159-cm
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739193408452-1r
Go to your Sync screen fully disable all the connected Vehicle controls, leave off for a minute or so, then switch the master and all subordinate approvals back on, it takes a good minute to go through all the sub-menus to get them back on.
Also have you tried LOG OUT of Fordpass? Then log in again?
Try this first.
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739194733490-p6
LSUT1GER
LSUT1GER
Slidell, LA
Computer Engineer
I didn't try logging out but I did uninstall the FordPass app and reinstall it. Afterwards, I had to log back in, and the same results - no state of charge updates.
Good point, I try my hardest to avoid uninstalling, PIA setting up PAAK and backup passwords, mine never seems to allow prior PW codes to be reused.
If the toggling of connected Vehicles features fails to work, there has to be an issue with your TCU
LSUT1GER
LSUT1GER
Slidell, LA
Computer Engineer
Thanks! I'll have the Ford Service Department at Superior Ford check out the TCU tomorrow while they are doing the recall work.
LSUT1GER
LSUT1GER
Slidell, LA
Computer Engineer
It's definitely not the FordPass app. Here's incorrect state of charge displayed on both an iPhone 15 and an android S25 Ultra. See below:
Ford F-150 Lightning FordPass NOT displaying the current state of charge and unable to set to 100% 1739276760484-xx
I'm on the way to the service department to get the upper ball joint nut/bolt replaced and to resolve/replace the TCU.
Zed
Chuck
2022 Lightning Platinum Rapid Red
I just now checked for updates in the Play Store and found that 5.12 is available for Android.
