This will be my last attempt at a Lightning Road Trip
Rip
Rip
2024 Lightning Platinum
Quality Consultant
It’s not luck, it’s an adjustment to EVs. I’ve been driving them for over a decade now and I go significant distances. It’s become second nature to me - I actually bug out when I have a gas rental.
If you have a Y the Tesla integration helps. Pick up ABRP for now, it’ll simulate what Tesla gives you for routing and charging and you won’t miss a beat especially with OBD live readings.
Maine to Florida is a different beast and takes some knowing. For example, do NOT plan to stop in SC. I top off in NC and always plan to drive through SC. The earliest I’ll stop again is GA, but I’ll push to the FPL chargers in Jax. Knowing the route definitely helps in that case.
Good luck! We’re willing to help on here if you need
Hey, I appreciate it. Any recommendations for an OBD?
Yellow Buddy
Smart Ass
I cheaped out a bought a VLinker, it’s works ok but I recommend a OBDLink MX+ since it comes with an app as well.
Oh another one - avoid any charging in Richmond VA. That adds an hour to my trips usually. I’ll stop before or after but never in.
Rip
Rip
Quality Consultant
Richmond cost me a lot. I found a Tesla Supercharger station that FordPass and the Tesla app said was compatible. I had to take a 20-minute detour to get there, and found that none of them worked with the Ford. I ended up driving another 10 minutes to some EVConnect chargers that worked well (and were in the parking lot of a 5 Guys). So, yeah, avoid Richmond.
I only made a couple of stops in SC. One was in Florence, an EA station that was easy to get to and worked well. It was next to a Super Walmart, and I got lucky and got on a charger right away. There are only 4 there, though, and only 2 are rated at 350 Kw. There was another one on the way down near a bowling alley that was an older Tesla station with pretty slow (95-105 Kw) service and no amenities.
dww
San Antonio, TX
F150L, Tesla 3P, YP
Why on earth would Ford need to create its own charging network? Because Tesla did? Tesla built its network out of necessity—there were virtually no chargers at the time. That was over a decade ago. In 2025, with nearly 70,000 chargers in existance, the idea that Ford needs its own branded network is crazy. The navigation system already finds any available charger, not just ones with a Ford logo.
Would you expect to fuel a Ram truck exclusively at Ram-branded gas stations?
Bottom line: Ford is already investing billions in manufacturing. Expecting them to sink billions more into a charging network—when dozens of networks already exist—just to support a mere 70,000 EV sales per year? That would be financial suicide.
Because Tesla chargers are the only reliable ones. EA? 50/50 there will be a line and a tight spot for a truck. Anyone else? 70% more than half are offline. 50% chance they will de-rate or not connect. The last non-Telsa I tried had 50% off line and the one I used de-rared from 150kw to ONE kw within 3 minutes. I moved to the other working one and it instantley de-rated. I got connection charges for all attempts.
CavRider
Somewhere near Minneapolis
F-150 Lightning, BMW i4, some others
Umm... Who owns ABRP? Rivian. Why would they license it to any other car company?
Did not know about the acquisition but that is exactly what I was suggesting. License/acquire rather than build in house. ABRP was just an example that came to mind quickly.
Why would ABRP license? To generate revenue. I bet Ford will peddle more vehicles with navigation included than Rivian can ever hope to.
RailroaderJ
Julian
2023 F150 Lightning Antimatter Blue
The East Coast sounds challenging. I'm on the I-30\I-40 corridor and have had good experiences with EA, GM energy, and Tesla super chargers. Google maps will tell you if the charger is compatible. I'm finding most 150kw Tesla chargers ARE 🚫
PJnc284
Garner, NC
ALL 150kW (v2) Supercharger locations are incompatible so avoid any with the silver collar on the handle as they 100% won't work. The v3/v4 stalls have a black collar on the handle but ymmv as most but not all should be available.
kstype
Kurt
Pennsylvania
Senior Systems Engineer
I have to concur with the other comments, I have travelled on many LONG road trips since I took delivery of our Lariat ER in 1/6/2023 and I currently have 63,970 miles…major road trips included:
SE Pa to West Palm Beach Florida (first week we had it only EA and EvGO chargers) (2,200 miles RT)
SE PA to Lexington VA (800 miles RT)
SE PA to Dearborn, MI Ford HQ (1,100 mile RT)
SE PA to Chicago, IL (1,400 miles RT)
<Recieved NACS Adapter June 2024>
SE PA to Oklahoma City, OK (2,500 miles RT) almost exclusively Tesla
SE PA to CT and Albany (about 850 miles RT)
I took some time to research in PlugShare and used ABRP and EA and Tesla apps when needed and never had any issues or was close to running out of energy.
it’s not as convenient as a gas station every 50 feet but I was able to do all this without any issues.
Ford F-150 Lightning This will be my last attempt at a Lightning Road Trip IMG_3868
Ford F-150 Lightning This will be my last attempt at a Lightning Road Trip IMG_0387
Ford F-150 Lightning This will be my last attempt at a Lightning Road Trip IMG_2839
Ford F-150 Lightning This will be my last attempt at a Lightning Road Trip IMG_2302
Ford F-150 Lightning This will be my last attempt at a Lightning Road Trip IMG_1815
I've mostly skimmed to catch up, but I don't think I saw anyone bring up how the GOM will affect Ford's Nav planning. Several times I've gotten a warning about not reaching a destination. I know what efficiency I'm getting and can do the math, which tells me I'm fine. Just ignore the warning and continue with your plan. You can always slow down to conserve range.
RailroaderJ
Julian
I've had the Ford Nav run spot on with range and suggested charging stops. I would test it on route with plenty of chargers first.
Erik
2023 Ford Lightning XLT SR
If you cannot use the built-in navigation then it IS a failure of the truck. Yes, we all know better ways to go about this, but if the truck nav says it provides those features then it should actually provide them.
I have to be honest, the folks here are kind of being jerks about it.
Two things can be true- yes, the Ford Nav software is hot garbage. It would be adequate for an ICE vehicle but for an EV it is practically unusable. OP is correct about that.
It is ALSO true that OP should have done some basic research before buying a $50-$90,000 EV. Unless your head is stuck deeply upside down in a sandy beach, people must know that our EV DC fast charging infrastructure is lacking, especially in some western rural areas (Idaho, I am looking at you). I agree that forum members could perhaps be a little less annoyed and a little more understanding, but I get it. We see these posts weekly about someone complaining that they can’t road trip in their Lightning and it’s untrue. The truck (even the SR) is a great road trip vehicle. My XLT is the best road tripper I have had, over 30+ years of heavy driving. But it does require some pre-trip and during-trip planning and flexibility. OP- If you’re unwilling to be flexible and learn something new, simply don’t buy an EV. Period. Even a Tesla will frustrate you, though likely not as much.
No need to be able to identify chargers by color since the apps tell you whether they are compatible or not. So MMNV (My Mileage Never Varies).
PJnc284
Garner, NC
While mostly reliable, even the apps aren't 100%. I've came across several in PlugShare that are listed as Tesla only but are open to others. Also seen a couple that the Tesla app listed as compatible but were down for non-Teslas for one reason or another including one that was working previously but was then inaccessible for a month+. Figures I would try to use it during that time.
Right. I found a location where it said Fords had charged, a new V4, not yet marked as open for non-Teslas. I went there and charged fine.
Yellow Buddy
Smart Ass
The same reason they bought ABRP. It gives them a jump start on the data.
Rivian ultimately bought ABRP after significant complaints about their route mapping (raises hand, I’m one) ABRP gave them years of data from Tesla owners (and others) that they wouldn’t otherwise have had access to.
So I think offering a license deal may not be out of the realm for several reasons.
1) More/better data about charging ultimately makes their own software better.
2) They’re still in a cash burn, licensing offers cash flow with minimal capital investment and development.
3) They already engage in self competing agreements (VW / Scout)
