oddlou
Lou
Los Angeles, CA
2021 F-150 Star White Platinum 4x4 Powerboost
Could someone with the X4s installed measure the height between the closed cover and bed? I'm still waiting on my truck and just wonder how tall something can be and still fit in the bed with the cover closed. I have a large cooler I want by to put in the bed on trips and I'm not sure there will be enough height for it.
21 inches from the higher ridges to the bottom of the X4S.
Separately, does anyone have a ridge on top of the cover after installation? It's not a huge deal, I suppose, but the pictures and videos I've seen online are all perfectly flat...so this is bugging me.
Ford F-150 Lightning Installed a New Bak Revolver X4s Tonneau Cover PXL_20210416_232904960.MP
Ford F-150 Lightning Installed a New Bak Revolver X4s Tonneau Cover PXL_20210416_232842533.MP
Ford F-150 Lightning Installed a New Bak Revolver X4s Tonneau Cover PXL_20210416_232850085.MP
Longhorngary
Longhorngary
Austin, Texas
2017 Ford F150 302A soon to be 2021 F150 KR PB
no mine is flat
RJ82
Rich
Missouri
2021 F150
Been looking at x4s too...and that would bug me for sure.
John_C
2021 F150 XLT 302A PowerBoost
That is because you did not add the 1/8th inch washers on either side per the installation instructions. The bed is slightly too wide, which causes the rails to not carry the cover correctly. The cover will sit on top of the channel instead of in it (where it will be flush).If you lift the weather strip, this is what it will look like. Just loosen the clamps, add an 1/8th washer between the side of the bed rail and the cover rail, and repeat at all 6 of the cover rail clamps.
Ford F-150 Lightning Installed a New Bak Revolver X4s Tonneau Cover 20210421_094345
Ford F-150 Lightning Installed a New Bak Revolver X4s Tonneau Cover 20210421_094405
This is with the washers:
Ford F-150 Lightning Installed a New Bak Revolver X4s Tonneau Cover 20210411_093334
oddlou
Lou
Los Angeles, CA
Lol, I don't fight on the internet, but, wow, the absolute certainty you express while jumping to conclusions and being wrong at the same time is impressive! First, I did follow the instructions, including using the washers. Second, I took a look at the panels under the cover and found that one of the metal pieces isn't connected to the metal slats as it should be.
Ford F-150 Lightning Installed a New Bak Revolver X4s Tonneau Cover PXL_20210417_174154556.MP
Longhorngary
Longhorngary
Austin, Texas
I would contact the manufacturer Truck Hero/ Bak Industries along with your seller. I think they will make it right.
oddlou
Lou
Los Angeles, CA
Already done! I emailed last week and received a reply saying that it'll take a few days to get back to me with a full response. I'm assuming they'll make it right. From everything I've seen, they seem to stand by their products.
John_C
My reply wasn't meant to come off that way, I didn't mean to sound condescending! Sorry if that is how you interpreted it, one of the reasons why text isn't my preferred contact method.
I've never seen that issue before with your cover, was it like that from the start? I worry that if I roll it up wrong/drive with it open, that might be the outcome.
oddlou
Lou
Los Angeles, CA
No worries, John! Text communication is fraught with misunderstanding! I was mostly amused by the certainty, tbh.
Yes, it came like that-the pics I posted were from right after I installed it. It almost looks like they skipped that piece when they did whatever they do (weld?) to put the pieces together. But it's stuck in that position, so maybe it was that the piece on the other side was connected at the wrong angle. It's like that the whole way across, so I don't think it's something you could do by rolling it up wrong or by normal driving. This, at least, seems like something that could only have been done when it was manufactured.
LTDXLT
Lance
2021 Space White F150 XLT
I did the same and got mine through Real truck...Arrived four days later and received a substantial discount by reaching out through the forum.
do you have the POC to reach out to?
hammer40
Vashon Island, WA
2018 F150 Platinum, 1970 F250
Business owner
My auto down works and I can close it with it down. I would say you are hoot to go.
The X4S looks really nice. I have the X4 and the felt on the underside just decided to fall off.
oddlou
Lou
Los Angeles, CA
So, I emailed them the pictures and they took care of me. They immediately sent me another cover (without the rails). I just had to destroy the old one (I cut up the top) and send them a picture to keep my current warranty. Easy peasy. Excellent company that stands by their product.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Something in my mind recently while doing yard work, had anyone with the X4 or X4s gotten a load of mulch, gravel, or dirt in the bed? I'm curious on how the side rails may hold up to something getting dumped into the bed.
Unfortunately, my cover is still pending a truck to put it on.
