Set up help needed
Rip
Rip
2024 Lightning Platinum
Quality Consultant
Great, thanks. Yeah, I have no problem paying for useful software...just wondered if it works better. Sounds like it does.
What type of splitter do you use? I see two types on Amazon...one cabled (probably not as useful in this case) and a couple that plug in and have side-by-side female receptacles for OBDs. One sort of swivels up and down. I have the MX+ already and have ordered a CX+, so the splitter idea sounds good.
@RickLightning pretty much nailed it. The difference for me is the paid version allows ABRP to use the data from the OBD to put the pre-plan into motion and useable on Android Auto. The charging stops and times can update based on the real time conditions. If I need to change something on the fly, ABRP has better filters to choose which charger I want to go to compared to Google Maps. I also like to pay developers when they come up with a good product, so the $50 a year is worth it to me. ABRP still routes around traffic like Google Maps, and has a less of the distracting characteristics and implanted ads that Google Maps has.
I don't disagree with some of what was said. But some other points.
1) ABRP is owned by Rivian. Let them fund it. I bought CarScanner, it's a one-time purchase of under $7 as I recall. ABRP is annual. We take trips 2 or 3 times a year.
2) GoogleMaps comes up with alerts like speed traps, objects on road, etc.
3) Using GoogleMaps with Android Auto, with the Mach-E (and soon the Lightning), will precondition on the way to a fast charger. ABRP will not (matters in winter).
4) ABRP offline has a slider, with + or _. Simple thing to hit either symbol a few times and true up the SOC%.
I run GoogleMaps (or Ford Nav) on the big screen, ABRP on my phone, and plane GoogleMaps on my wife's phone. I also have CarScanner on my phone. I found on my most recent trip that my phone couldn't handle the processing load (Google Pixel 6a), I know have a Pixel 8, will be interesting to see if it handles it ok.
B177y
Northwest of Northwest WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
I think with the CX+, you may not need a splitter. I think someone earlier in the thread said that OBD connector does both forms of Bluetooth. Double check before listening to me...
I had a cable splitter, but the cables eventually cracked and disconnected. I recently got one of the double males (one female). Just make sure the orientation is correct, so that you don't have an OBD facing up towards the dash as for me that wouldn't fit.
flypony53
Rodney
Houston, TX
Ford F150 Lightning, Tesla Model Y, Tesla Model S
The OBDLINK MX+ is made by a good company. I have that dongle plus their hard-wired EX. If you want one from them that is compatible with ABRP, you need their CX model.
I also have the VeePeak OBDCheck BLE that works good and is much cheaper. Works with CarScanner and ABRP. I do not leave it plugged in with the truck off though.
Here are what the ABRP folks recommend:
https://www.iternio.com/abrp-obd
I have the same VeePeak and it stopped working with ABRP for some reason. I went to the OBDLink CX and Paid for ABRP as the only real way to trip plan in the Lightning. Cannot with built in Navigation as it still cannot navigate to a Tesla charger, Apple Maps does not allow any customization (at least the last time I used it) for charger types and I think they allow for paid placement by brand as the last time I used it in a rental, it took me to a ChargePoint L2 charger instead of the EVGo that was across the street that did not even show in the list.
The only gripe I have with ABRP is it displays a different SoC % most of the time. I believe that is a disconnect in how ABRP rounds the numbers. Ford is showing the absolute 2 digit, meaning the battery is 74.7%, ford shows 74, ABRP shows 75.
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2017 Tesla MS90d, 1941 Lincoln V12
I have a different method. On a trip, I use the Tesla phone app to search for superchargers and write dow the street addresses of sSuperchargers that are useable with the adapter. Then I use the Ford app to navigate to chargers that are spaced where I want.
This is crude but easy to do for non-tech savy drivers.
Rip
Rip
Quality Consultant
All good to know. I have an Android phone (Galaxy S22 Ultra). I don't get Google Maps on my big screen without Android Auto, so I'm hoping (based on what I've seen in some of these threads) that once I have ABRP on the phone, it will show up on Android Auto. Is that not the case?
My luck I'll get all this installed and learn to use it and Ford will come out with a fully-functional Nav program...not holding my breath, though...
Paid version will show up. Unpaid will not.
