NHTSA Recall - Loss of Steering from Front Control Arm Separation (Impacting certain 2023 to 2024 builds)
Consolidated threads, let's TRY to keep critical issue discussions in one thread, thank you very much.
Mike G
N. AL, USA
Safety Recall 24S76 - Certain 2023-2024 F-150 Lightning Battery Electric Vehicles - Upper Control Arm Ball Joint Nut Replacement
Okay, so NOW the full recall has been released as of this morning (5 Feb '25). Number of vehicles went down by 2 (I assume they've already fixed those as part of the validation) to 11,291.
The date range was expanded by a day on either side of the original range, so that's now 5 November '23 to 13 February '24 inclusive.
Every one of the trucks are going to get something. Meaning when they do a torque check to find out if the nut meets the check spec...even if it passes the nuts are replaced anyway. If it doesn't pass the initial check the whole steering knuckle gets replaced.
Riverant
MA
2023 F150 Lightning Lariat ER
Had this done by mobile service today, at least the inspection. Torque checked out and the nuts were replaced.
Also on the plus side, the tech agreed to update my BCM so I now have walk away lock.
NikonJim
2024 F-150 Lightning Flash
Same for me on the recall, but I already had the walk away lock.
