richguy82
Richard
2023 Ford Lightning Lariat
If it is available in the "easy" mode, go to the BCM module in the easy option, and use the search box on the top of the forscan window (search for "window") and see what pops up, or scroll through the available easy settings. If it's available, it'll be in there.
Or try the "difficult" way and make a backup of current configuration and change the lines in the "As-Built" section according to post #1.
Thanks all
Thanks all
The "hard" way shows 8 lines needs changing, so there will need to be 8 easy modes. For example, there will be 3 in BCM, 2 each in both DDM and PDM and one APIM.
See this post.
richguy82
Richard
See this post.
I was using that post actually. In BCM it’s not clear which 3 need to be changed. It’s pretty obvious with the other modules. I’ll just do it in “As Built”. NBD. 🙏
Maybe some day, someone (not me) will come up with a true easy mode that has one checkbox that handles all the discrete modules.
If you’re curious after you do As-Built, you can go back to easy mode and see what changed. From what I’ve noticed, they are linked so changing a value with one method gets reflected in the other method. If you do let me know and I’ll update post 1 with an easy mode option.
