Brakes
Ron Roman
Ron
Sarasota Fl
2023 ford lightning lariat
Caretaker of property
2023 White Lightning
I'm at 28k miles
Anyone have guidance on when to replace front pads.
Put on new Michelin's at 21k.
I know it's heavy and it ate cheap Hankooks pretty fast. I know about regenerative braking.
Still.....who has done any brakes work
The truck has disc brakes on all four wheels.
Calipers, pads, rotors. Just like any other disc brake system out there.
Check pad life, check rotors for corrosion or glazing. Lubricate brake caliper pins.
Non regen vehicles can go for 100k km's before needing pads, unlikely to need pads anytime soon on the lightning.
53,000 miles and no need for anything... tires are looking almost new, and Ford's service department said that brake pads show 7/8...
Ron Roman
Ron
Sarasota Fl
Thanks.
Hoping for owner who has had to do a brake job and at what interval.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2002 Jeep Wrangler
Mech Engineer
I just had my truck in for inspection. After 2 years, I'm at 37,000 miles and still have 8mm left. New brake pads start at between 10-12mm, so we have a long time if you replace at 3-4mm.
Thanks.
There are more Lightning owners who have replaced battery modules than brakes. They are still a wear item but just barely.
Similar threads
