2023 F150 Lightning Platinum
Speedometer is displaying km/h now again. In easy mode I did the following sccm changes:
Speedometer calibration: Northamerica -> Europe
Display Unit Selection Function: Imperial -> Metric
Country Code: US -> CA (used CA as metric is used there too)
br
F.
In your original post the only SCCM changes you said you made were:
Blink 3 to 4
rain sensor disabled to enabled
Markt non-European to Europe
The blinks change and rain sensor are straight-forward.
I meant to ask you what you meant by "Markt non-European to Europe". Sounds like you may have messed something up there originally and Easy Mode fixed it.
EDIT: Are you sure you did this in SCCM? Those values seem to be in IPC.
You are right. I reverted in sccm the market parameter to non-European too - forgot to mention that. The other changes are from IPC, not SCCM - my mistake.
digitaldad
2023 Lightning Lariat ER
The spreadsheet says B stands for Background whatever that is. I have concerns when folks post mods that may come from the ICE forum or other sources.
I have a database of about 50 Lightning As-Builts across all model years and trim levels and everyone of them has a 4 in that position. I also have a few ICE Lariat and Platinum PowerBoosts in my data and they also have 4. But to your point maybe the original source was copying from an ICE F-150 that had a 6. I haven't added all variants of ICE to my data.
So I'm not sure why he disables SS but enables B ("2"). I agree with you that the logical value would be 0 if you want to disable the Splash Screeen. Did you try 0 and did it work for you? I haven't tried it.
In regards to "IPC Quick Boot"...on Saturday, I tried both:
IPC 720-07-01 xxxx xxxx 2xxx
IPC 720-07-01 xxxx xxxx 0xxx
No changes that I can see, looks stock/default (4xxx). I did reboot IPC modules after each attempt.
