jmyer72
Jason
2024 F150 Lightning Lariat ER
Service Advisor
I absolutely LOVE the final result of the rotary shift conversion in my 24 Lariat! I've seen a few different variations of this mod including cutting a hole in the dash and mounting it next to the steering wheel. I was planning on going that route but had trouble building the wiring harness. At the end of the day I'm glad I did because what I have now looks like just as OE as the dash mount, I still gain use of the workspace when in gear, the truck could be put back to original quickly and easily, the install literally too less than 20 minutes!! The first photo of the knob installed is in the raw finish how it arrives to you. I ended up hitting mine with a few coats of filler primer, doing a little sanding, and a final coat of trim black just to help it "blend in" a little. But I'm OCD like that. It totally looks good enough to run as-is.
HERE IS A LINK TO THE SHIFTER I USED. BEST PRICE I'VE FOUND ANYWHERE!
HERE'S THE LINK TO THE 3D PRINTER CUBBY/MOUNT
The mount will likely show "SOLD OUT" but just message him directly and let him know you want to be on the wait list. Ever since posting mine on a couple Facebook Groups, he's been getting slammed with orders.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 482650262_705845701767622_1341843731018315033_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 482978960_2944250429076241_3150479634266662396_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 482972951_2944250452409572_2834201371685071624_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 482959657_2944250529076231_4155398790283176069_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 483680793_2944250555742895_1966668537161014905_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 483894206_2944250585742892_439514270701677835_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 481298780_2944250479076236_1968773068887312094_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 482348686_2944250522409565_746226502153378358_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 482985170_2944250549076229_5910355619418081901_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 482985721_2944250579076226_8762204310675264365_n
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 484181942_2944250485742902_6496479684943812204_n
Nice job with the finish, looks great. I've never had a complain with the shifter but that looks really nice. If the install is that simple, that's a very affordable mod.
I'll be interested to see how it handles the summer. Can get over 140F interior temp in the summer here. PETG is pretty heat tolerant I think, ABS would be better but is way harder to print.
21st Century Truck
Martin
Dang but I love this!
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), F150 L
Does the connector plug right into the existing wiring harness? If there is no wiring modification needed I might consider this.
explosive0
2024 F-150 Lightning Platinum
Curious about this, and how this plays with overall warranty.
jmyer72
jmyer72
Jason
Service Advisor
Yes. No modifications whatsoever. Direct plug and play
