21st Century Truck
Martin
2023 Tab 320S Boondock
Heght: 8 ft
Weight: ~2350 lb loaded
2022 Lightning Lariat ER
Flat ground efficiency 1.4 mi/kWhr 55mph
Varied/hilly terrain (Montana/Wyoming): 0.9-1.2 mi/kwHr 55mph
Nice teardrop! I love these things.
TomB985
Isanti, MN
2022 Lightning XLT ER
Thanks, just updated the spreadsheet!
I traded my Flagstaff A-frame camper for a Nucamp T@b 400 last month, but I had a tailwind for the entire trip home. I’ll update next spring when I have some clean numbers, but it’s looking like 1.1-1.2 at 60 MPH. Not as good as I hoped.
I arrived in NH last night after pulling 3,200 miles behind my old Expedition and only averaged 10.7 MPG.
Ford F-150 Lightning DATA THREAD: Post your tow and efficiency! IMG_4872
rockhead
Glenn
BC
F150 Flash
Geek
120 kilometers on 54.45 kwh at 95kph, or for those of you living in the past 🤐 59 mph, 1.38mi/kwh 3600 pounds of trailer and 'payload' , net elevation gain of zero (round trip) with ~600 meters or 1800 feet of climb and descent
Ford F-150 Lightning DATA THREAD: Post your tow and efficiency! 1741409653455-ve
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
That's a unique rig! Just clarifying.... you went 120kms round trip, and it used a total of 54.45kwh? So, efficiency avg of 45.4kwh/100km?
That's not too bad overall....winter towing, and you'd have a theoretical 300km of range?
I am trying to guestimate my efficiency if I go ahead with a 17ft travel trailer, and upgrade the family from our tent trailer.
rockhead
Glenn
BC
F150 Flash
Geek
It is warm and the speeds were low, YMMV !
ddbrooke
Natrona Heights, PA
I've been towing our GeoPro 19FD for the past two years. It weighs around 4000lbs and is 21' to the hitch. I try to keep my speed to between 55-65 to get 1.2-1.3/ kWh. Speed kills and I see it right away. If I run at 70mph my efficiency drops to 1.0-1.1. In the norther mountains of PA there is still a scarcity of DCFCers so giving up even 10 miles of range to go a little fast might leave me short of getting to a place to charge. All that said, I love this truck and towing with it is smoother and easier than anything I've towed with.
Ford F-150 Lightning DATA THREAD: Post your tow and efficiency! IMG-6205
