PAAK door unlock - drivers side
What also boggles me is that PAAK works on bluetooth and it needs to be very close for it to work. However, I can open the frunk or tailgate with my phone from about 50 feet away, which is also bluetooth. šŸ¤·šŸ¼ā€ā™‚ļø
Working as designed. The phone or fob must be within 3 feet of the door. This is to prevent some stranger from accessing your vehicle in the parking lot while you are in a nearby store (for example).
Ford F-150 Lightning PAAK door unlock - drivers side IMG_1154
This is from the Mach-E manual, but the Lightning is the same.
GoHawks
2022 Lariat Lightning ER
Did you ever get this totally resolved? Iā€™m dealing with the exact same issue with my 23 Lariat. Out of the blue driverā€™s side front and rear doors handles will not lock or unlock. Just started a few days ago. Passenger side is fine. PAAK still works to start and drive the truck. Iā€™m at a loss for why all of the sudden this happened. Hadnā€™t had an issue since I bought it last spring and now itā€™s acting weird.
This issue has reappeared for me. PAAK works on the passengers side but not on both drivers side doors. Unlock function in the app works and touch lock/unlock works on all doors with the fob. So a software issue has reappeared unfortunately. I also have a software glitch with ā€˜my keyā€™ which requires GWM updates at the dealer. I just donā€™t have time to give up the truck. DCDC,BECM,ACM,GFM2,APIM were all recently updated by the dealer in a troubleshooting exercise which most likely reintroduced the issue.
Jim657
Guelph Canada
23 F150 Lightning Lariat , 22 Mach E GT
Did you ever get your issue fixed? My Lariat started doing the same thing to the point where none of the doors will open with the PAAK. When I go to lock the truck, it just keeps beeping thinking the key is inside. Iā€™ve removed all keys. Reset the system still the same problem.
The_Zeker
Matt
2023 Lariat Lightning
Still having this issue. Will probably end up taking it to dealership, but I almost guarantee theyā€™re going to blame the phone and tell me itā€™s a phone software issue, which itā€™s not. Something is wrong with whatever reads the phone on the driverā€™s side doors. Any suggestions on how I should describe this issue to the dealership?
Jim657
Guelph Canada
āø»
When I eventually take it in, Iā€™m going to describe it as a truck issue. I have eliminated every other possibility. I removed all the phones, reset PAAK in the truck. I also deleted and reinstalled FordPass. I tested another phone by setting it up as a key, but the same issue occurred. My wife set up her phone as a key on my truck under a different FordPass account, and she experienced the same issue. However, she has a Mach-E with PAAK and has no issues on her vehicle.
I even went as far as removing the battery for 30 minutes, but still no luck. I assume the truck has two Bluetooth antennasā€”one for proximity detection and another for in-car key. I suspect the antenna responsible for detecting whether the phone is outside the vehicle is not working. This would explain why the truck keeps honking when I try to lock it (thinking the phone is inside) and why it wonā€™t unlock (assuming the phone is still in the vehicle)
