2025 bricked at 1000 miles {fix post 36}
Thunderand…
Patrick
2025 Lightning Flash
FireFighter
One week old 1000 miles and the truck bricked. Every warning light possible came on and truck shut down. Fantastic. Anyone else seen an issue like this?
TMND
usa
Lightning
ag
2023 er. Hasn’t let me down once yet. Sorry to hear… warranty will make it right.
Thunderand…
Thunderand…
Patrick
FireFighter
Yeah it’s fully covered but wtf right!? Sitting here right now waiting on a tow
B177y
Oly Pen, WA
2024 Pro ER Max Tow
Like @Heliian suggested. Open the funk, pop off the back panel where the 12 volt battery is and wiggle the + and - connections to see if they're loose and try to tighten them if you can. May solve your problems while you wait. You probably won't even get dirty.
Thunderand…
Thunderand…
Patrick
FireFighter
I tried at it’s tight as could be ?‍♂
B177y
Oly Pen, WA
2024 Pro ER Max Tow
Symptoms sound like a 12 volt as described by many on the forum. It hasn't happened to me yet (knocking on wood) so I'm just going off other forum descriptions. I had a motorcycle that basically did the same thing (all of the errors at once) when it's battery got low...
Are you able to get a jump or do you have a battery jumper box? Use the jump points under the side panel if you do.
Worst case, the tow truck will take you to the dealer. They can test/replace the 12 volt. That's my guess. Let us know if it's something else.
Thunderand…
Thunderand…
Patrick
FireFighter
I mean truck is fully (70%) charged and turns on but then warning after warning. I’ll post here when dealer lets me know what it is.
A 2025 Flash should have a fresh strong 12v battery, something odd going on, let us know what the dealer service discovers.
While you're waiting fill us in on the truck details, is yours a 131 or 123 KWH battery?
Build date?, look at the door jam weight/tire pressure spec's sticker, the dates are top center and bottom left of center (reverse order)
Ford F-150 Lightning 2025 bricked at 1000 miles {fix post 36} 1745846490972-5x
Thunderand…
Thunderand…
Patrick
FireFighter
While you're waiting fill us in on the truck details, is yours a 131 or 123 KW battery?
Date 1/25
1202501095961
Looks like you have a Job-1 131 KWH HVB (eight character is = 7)
Job-2 trucks have U for 123 KW HVB
