APIM 7D0-01-01 xxxx xxx* xx-- 4=ten presets, 0=six presets, 2=5 presetsLivnitup, wondering if you have any information on the following topic: California - Is there a Sync 4 difference between models? | F150gen14.com -- 2021+ Ford F-150, Lightning EV, Raptor Forum (14th Gen)
I only have 6 of the 10 cards but the image he has is not using FORScan the way you have us doing it. I tried looking through the APIM sheet but couldn't find this or looked at it and didn't know it.
I would love to enable all 10 cards vs. my 6.
Are you using the newest version of FORScan here? https://forscan.org/download.htmlTried doing this and kept getting “service procedure has been interrupted”
I researched disabling the Pedestrian Alert and looks like the only way to do that is pulling the wire on the speaker. Also, nothing for disabling the "keep hands on wheel" message.I have a 2021 Powerboost Platinum with Pro Power 7.2kw we can play around with using forscanBuying dongle on Amazon now! I’m getting rid of the stupid double honk first.
Can someone please help me disable the pedestrian alert system on this thing?
Does anyone else here know why this truck shutters when I give it light power to pass. Or if the auto cruise accelerates after I pass someone, it shutters always.
I have an itsx and I performed data log and I can see transmission converter slip pid jumping around when the shutter is occurring. Feels like a cylinder missfire often as well, so I don’t know.
I think there is some way to look at some of these things. I’m wondering if anyone has looked into the 2021 hybrid trucks to see what may be available.
I know of one on my wish list! Disable the 30 second lane centering disable if hands not on steering wheel.
If anyone knows what code I should should change for that jewel, please let me know because I’ll have the usb dongle soon.
Hanging a 2.5 lb ankle weight on the steering wheel makes the lane centering quite nice on long highway trips. I don’t trust it a lot when there’s much traffic but for light traffic it’s great. If you do a forum search, there’s another thread on this.I have a 2021 Powerboost Platinum with Pro Power 7.2kw we can play around with using forscanBuying dongle on Amazon now! I’m getting rid of the stupid double honk first.
I second this.I want to have this done on mine. Anyone know how to get this done?@Livnitup do you know if there is a way to get the rear c clamp lighting to be on with the DRLs like in prior years? Still waiting for my obd ex cable to arrive so I can delve into the settings but hoping to see if someone had already figured it out.
Thanks
Did the auto start/stop disable. Does this mean it worked?Are you using the newest version of FORScan here? https://forscan.org/download.html
Here are the error codes I pulled using forscan:Hello again @Livnitup I replaced my Lariat high mirrors with OEM factory tow mirrors for the 2021. I got a hold of the ML3Z-17696-CA mirrors. However, upon install, BLIS and zone lighting work, but power adjust does not work correctly. It will only adjust left and up but not down and right. Same issue on passenger mirror as well.
Incidentally it was the exact same issue when I installed aftermarket 2018 tow mirrors on my 2021. I subsequently purchased the OEM ford 2021 mirrors but same issue.
Could this be related to a mirror unit re-sync/re-initialization issue? Can forscan help me reset the mirror controls?
