jamesaF150
CA's do not have the memory function on the 302A XLT. These mirrors work mostly. The dealership needed to calibrate the cameras.. the problem is the amber side marker lights will not turn on. With tow mirrors, when you start the vehicle the amber light turn on and stay on as running lights (marker lights), they also blink as turn signals. Currently the marker lights wont turn on at all, but there are two small LED lights near the end of the amber strip that blink like turn signals, and when you unlock. There should be a way to turn the two amber strips on.
Do your amber strip lights come on with your install?
740/741-03-04 | **xx | xxxx | xx-- | Telescopic Mirror: 00=disabled, 01=enabled |
740/741-03-04 | xxxx | **xx | xx-- | Side Turn Indicator: 00=disabled, 01=enabled |
These are in the DDM/PDM
