โœ… 9/05 Lightning Build Week Group
wait until 2200 hrs EDT
I have only one volunteer to sample for this week, make sure you all share the top margin with all the codes, sanitize your VIN if you're concerned about interlopers
Example of what I need to see for sequencing values
Ford F-150 Lightning โœ… 9/05 Lightning Build Week Group 1661391052942
Reactions: kab
Will post as soon as I see anything
Eh - 2200 hours and still nothing. Gonna call it a night and check again tomorrow. Will still post for whatever tracking info you need.
kab
Carroll County, MD
Window sticker showed up sometime between 0515 and 0615 EDT, but Ordertrack.app showed my blend date by 0450 EDT (even though I could not see the window sticker yet ot find that on any of the Ford pages at that time)
1. 14351
2. 120220911 8033
3. 572/595
No scale delete!
Max Tow package is there too even though I added it 4-5 days after receiving my VIN (I was nervous that it wouldn't actually add and was waiting until I saw it on the window sticker to believe I was able to make that change so late)
Initial view of sequence numbers, remember that SQ2 recycles after 8999 to 8000
@williams your sticker does not generate, did your build week change to a later week?
Ford F-150 Lightning โœ… 9/05 Lightning Build Week Group 1661432591543
Reactions: kab
@TaxmanHog Can you remind me the significant of Sq-2? Sq-1 is total trucks build to date and Sq-3 is your number in the build week correct?
SQ1 would seem to equate to total production, but the highest number seen so far is @hdeitzer at 20571 but his truck was built in May delivered in June, and there are many samples of duplicated use of the same number, so I don't think it's total model/year production. The lowest forum member is 3883 @monsterlag built in May, Delivered in August.
SQ2 runs for a 1000 units before recycling [8000 to 8999], don't know why they do this.
SQ3 is the specific truck to be built in the build week, assuming they go one after the other in proscribed order.
The SQ1, SQ3 and build week volume numbers are modified 24 hours after initial sticker run on all trucks with special handling requirements, (mostly we see that as the trucks with spray in bed liner).
Did anyone order spray in liner for this build week?
I'm curious what your numbers show.
kab
Carroll County, MD
gwoodyard
Kansas
2022 F150 Lightning
Here is my window sticker with spray-in liner. Hope this helps.
Ford F-150 Lightning โœ… 9/05 Lightning Build Week Group windowsticker
Mine has the spray in liner as well.
Could you pull a fresh copy of you window sticker the SQ1 & SQ3 values should have changed today
