Vulnox
Livonia, MI
2021 F-150 Lariat 502A, 3.5L PowerBoost
I got the truck this past Thursday, but did a few things to it.
-Installed Bakflip MX4, now on its fifth F-150, but first EV F-150. This tonneau cover has been a trooper.
-Installed dash cam
-I got the Ford molded mud flaps and used the paint marker idea from this thread but we ended up doing white instead of the blue. I liked the blue idea, but the white is a lot easier to see and goes well with the truck.
-I did the adjustment for my driver door as I could hear the seals rubbing over bad roads that others on here discussed and provided a solution for. Very easy and truck is much quieter.
-My usual array of FORSCAN mods to turn off the double honk (although I learned after this is a menu item on 2024s), removed the "full view not available" from the rear camera, and changed the number of signal flashes for lane changes.
I have the frunk nets coming today, which is less a mod and more just adding in something Ford stripped out, but happy so far.
I am debating if I want to reinstall my bed boxes or do something different. Having the frunk opens up a lot more options.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_1627(1).JPEG
Gerstein1989
Alexander
Barrie, Ontario
2024 Lightning Lariat
Plumber
-Installed dash cam
What did you do to your driver’s door to get rid of those noises? It’s driving me insane.
Vulnox
Livonia, MI
Gerstein1989
Alexander
Barrie, Ontario
Plumber
KurtsRPMGarage
Kurt
Orange County, CA
Did three things to my lightning this week. First I was inspired by a brandon flash video to finally pull my front license plate off and plug the holes. Painted some plugs from a local auto parts store and it looks great.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_8505
Next I was jealous of the higher end trucks painted mirror caps but am too cheap to pay the 400 plus to get them from a company like lethal performance. So I bought some cheap mirror covers in white off amazon and then painted them to match my avalanche color.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_8506
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_8504
Third I wanted to give my truck a mild level to give it a little more clearance. My goal is to keep the stock size tires and hopefully do as little damage to the range as possible. So I slapped a 1.5” level on the front and am very happy with the results. Got a quality alignment the next day. I have driven about 280 miles the last two days and my efficiency is sitting at 2.4 miles per kWh with about 80% of that being freeway driving. Thats near as makes no difference what I was getting pre level.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_8548
Bought seat cover after using towels stuffed under headrests that never stay for the past 12 years (moved from old truck). Bought one for Mach-E also. Price dropped for Amazon Spring Sale and retirement says time to spend money.
https://amzn.to/3Y0j995
Also got rid of leaking old compressor that my father in-law gave me with a new compressor last fall. Decided that the old reel he had in his stuff wasn't worth mounting so put it up for sale and bought a retracting one.
https://amzn.to/4j2vgKC
Also bought non-vehicle items like scale for my homebrewing.
Reactions: GDN
LUXMAN
F150 Lightning PRO and XLT
Pilot
Do you have a link for the Amazon caps?
Did they fit on easily?
And do you think the white color they come in is close to the Oxford white?
Thanks
KurtsRPMGarage
Kurt
Orange County, CA
Thanks
Mirror Link
I think it matches Oxford White pretty decently. There is a photo in the comments of a white lightning so I will let you be the judge.
Other links for the leveling kit in case anyone is interested.
1.5" Leveling Kit
Camber Kit buy two to install on both lower control arms.
LUXMAN
Pilot
I found a great seatback hook design online for the previous generation F150.
I stretched the design a little bit to fit the lightning headrest.
I made a blue one for the wife's blue XLT and a white one for my white PRO
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_1390
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_1392
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_1394
you may notice two different color filaments on the white one. Had to switch brands in the middle when I ran out.
butterfb
Brett
Orlando, FL
2023 Lightning
Senior Support Engineer
That looks great, I have been playing with printingnthe weather charger cover. Planning on adding a lip so a bag can be tied around the charging area covering the larger hole. Had to make a change to my settings to make the top level directions line up better after this test.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? 20250418_151912
LUXMAN
Pilot
I am not sure what this is for 🤷‍♂️
butterfb
Brett
Orlando, FL
2023 Lightning
It covers the charge port while the charger is plugged in helps to keep rain, snow l, etc out of the connections. Some have purchased for when it snows and freezes again on the connection I guess it can cause issues. I'm mostly planning on using it cause of the rain we get here in Florida.
LUXMAN
Pilot
OK. Gotcha. I see that now. That looks pretty cool and even covers the hinge.
LUXMAN
Pilot
Thanks to @KurtsRPMGarage
I got the mirror caps for my Oxford White Pro.
I think they match pretty well for the sub-$40 price and dresses it up nicely
Mirror Link
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_1397
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_1396
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_1406
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? image
flyct
Jerry
South Florida
'24 F-450 Platinum & '234Ford Lightning Platinum & 2 Tesla Model Ys
Blissfully Retired
