✅ 5/16 Lightning Build Week Group
FinsNBolts
Clearwater, FL
2022 F-150 Lightning Lariat
Apparently I need to be here... Have my Vin and Window Sticker, no module data yet.
Very odd - when I use the tracker on both the Ford site and the forums, I get nothing. But the window sticker link and module data link work. Anyone else have this or thoughts on a resolution? Ford Chat support said "call dealer," but did confirm the status as "in production."
ive been having problems with the tracker too, lately. When the tracker says order number, it doesn’t mean the online order number. It means the four-digit order number that can only be obtained from your dealer system.
If you have the correct four-digit order number, then it may just be that the system is down, because the tracking page isn’t updating for me either today.
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
You can get the order number from your window sticker, no need to contact the dealer. There is a field called "Item #" near the bottom of the window sticker, it will have some digits in the form XX-YYYY. The YYYY part is your order number.
FinsNBolts
Clearwater, FL
Thanks! Confirmed that’s the same number!
Yes, if you want to know your WBDO order number, it's visible on your window stick, as highlighted in this sample, the 7171 is the order number for this FLEET BUYER/ORDER, I've noticed a consistent trend, when the sticker has a BLUE outline color AND says SPECIAL ORDER, like this it's a FLEET order notice this PRO has an ER battery, the ONLY way those can come is via FLEET ordering!!
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=1FT6W1EV2NWG02616
Ford F-150 Lightning ✅ 5/16 Lightning Build Week Group 1652214914390
Now that you know the WBDO order number you can use the other FORD and third party tracking systems
neririn
Usa
F150 MachE
Build week is 5/16, but no window sticker yet. What am I missing?
Vorador
F150 Lightning, Ford Escape
You should have had your sticker last week. Sure you are entering the vin correctly?
neririn
Usa
F150 MachE
I am sure that is the problem. I was assuming it was available on the Order Status page. How is it procured?
Vorador
Enter your vin at the end of this url: windowsticker.forddirect.com/windowsticker.pdf?vin=
MapleMan650
Santa Cruz Mountains
'22 Ford Lightning Lariat ER, 2017 Ford Mustang GT
I.T.
Can’t wait to see how these first deliveries go. I’m trying to time the selling of my current truck so I’m not truck-less for too long.
Vorador
Same here. Selling my Model y before the truck gets to the dealer.
Good luck Ladies & Gentlemen
Ford F-150 Lightning ✅ 5/16 Lightning Build Week Group 1652699619508
Ford F-150 Lightning ✅ 5/16 Lightning Build Week Group 1652699667868
Greased Lightning! ⚡️
Mex
2021 Mach E GT, 2019 Land Rover Discovery HSE
El Jefe
Not sure what all the sequence numbers mean but here's my info:
Dealer Priority: N
Est. Build Week: 5/16
Blend Day: 5/16
Trim: Lariat
Color: Stone Gray
Battery: SR
Towing Package: Max Tow
Last 6: G05XXX
Sq-1: 17452
Sq-2: 8141
Sq-3: 244
Total Prod Week: 301
I assume this means mine is #244 out of 301 this week?
Dealer Priority: N
Blend Day: 5/16
Trim: Lariat
Color: Stone Gray
Battery: SR
Last 6: G05XXX
Sq-1: 17452
Sq-2: 8141
Sq-3: 244
Not 100% sure if 301 are being built with the spray-in bed liners, this lower # range are randomly sprinkled in with the larger group (685) of production with-out spray in I suspect that the total actual planned volume is only in the area of 685 this week, (the biggest so far), you guys are just segregated because of the post line actions needed.
I can add you to my standalone sheet which is what I use to generate reports, but do consider registering with the official forum table, if you do so they can do their analysis as well.
* Lightning Order Submission Form <-- Link to submit your order info.
* After submitting order info, please post a reply in this thread to notify us.
* Lightning Change Request Form <-- Link to submit edit request for your submitted order info.
In the meantime, could you include your sanitized order number, reservation date (ex...5/19/2021), Wave date (Ex. 1/6 and every 14 days there after) and Order date.
Ford F-150 Lightning ✅ 5/16 Lightning Build Week Group 1652718988579
