Everything I needed to get started I was able to find through the tutorial that @Livnitup put together and linked in the first post.Hello. where can i download the forscan program and how do i get the "license"?
Thnaks
Try this for the Keyfob Car Finder: 726-24-02 xxxx xxxx **-- Feat_Cfg [AUDIBLELOCKFEEDBACK] [VEHICLE]: 00=Disable 01=Enable 02=INOPCan confirm that Digital Engine/Coolant temp & Transmission Temp (720-07-01) works; Keyfob Panic Button (726-62-01) works; and Keyfob Panic Alarm (726-01-02) works.
As you suspected I could not get Digital Oil Pressure (720-07-01) to enable, nor could I get Keyfob Car Finder (726-28-01) to disable this time either. I was also unable to get the startup tone (doo-do-doo) (720-01-02) to deactivate. I didn't get the drive mode message or anything. The only effect it seemed to have was changing the first sound to the old school (think 2014 Escape) tone, then it switched back to the current tone. No big loss on that one, just figured I'd add to your growing list of results.
Disable (00) was successful, and does NOT interfere with mis-lock notification (ie honking if a door is not closed completely.) I did not attempt INOP (02) since Disable worked.Try this for the Keyfob Car Finder: 726-24-02 xxxx xxxx **-- Feat_Cfg [AUDIBLELOCKFEEDBACK] [VEHICLE]: 00=Disable 01=Enable 02=INOP
I think the OP was referring to the bed-view camera, that switches off after ~9mph.Can you clarify? Are you saying you dont like the speed limit sign on the cluster? If so, why not? I love knowing what the speed limit is especially if police are in the area.
Thank you!Everything I needed to get started I was able to find through the tutorial that @Livnitup put together and linked in the first post.
For the sake of ease, I'll re-link it here also:
https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
Can you share what you changed to make this happen? I want to do this!I can confirm I changed DRLs to fogs, turned off DRL low beamon a XL with halogens.
That is correct. This is the cable that I bought and I have had zero problems with it.Just double checking this is correct/best part to order:
Is there anything else I need?
Anyone figure out how to disable cylinder deactivation yet on 5.0?
Thanks in advance.
Not as of yet. Again, based off of what has been posed here and the other forum.Can anyone tell me if you’ve figured out how to disable the side panel in the 2021 f150 sync 4? Would love to have CarPlay or whichever app I am in to be full screen on the 12” screen.
The current version apparently has two modes of operation, "Easy" and "Advanced," however as Livnitup mentions in his tutorial, I have only used the "Advanced" option as it makes incorporating other people's finding easier and faster than waiting for an updated version of the software to come out.Is there not a new version of FORScan where you can read each item and enable/disable/change each by line item instead of going in and changing numbers?
Nothing on their site says 2021 F150, has anyone reached out to them for details?
