Littlefield82
Holly Springs, NC
2021 Lariat 502a PB FX4 5.5'
Civil Engineer
I see a “backup warning chime” and “city safety” in the IPC. Has anyone tried these on a power boost to see if it turns off the external noise generator?
I haven't heard of anyone doing that but I'd love to know if it works.
ptricky
Texas, USA
2021 F-150
I opened the IPC module in Forscan and was disappointed to see both these were already disabled. I enabled them (no change) and disabled them again (also no change).
Blinky
Manitoba, Canada
2021 F-150 XLT
ABS 760-04-01 xxxx xxx8 xx-- adds Trail
ABS 760-04-01 xxxx xx8x xx-- adds Rock Crawl. Thanks @Livnitup!!
What's the difference between these? Is "Trail" like the Tremor Trail Control? (i.e. off road cruise control?)
I have an FX4, so already have Rock Crawl and Hill Descent control, but was curious if it's possible to turn on the 1 pedal driving trail control like the Tremor has. Or if it has some hardware differences that are present on the normal FX4.
Gator87
Nathan
2021 F150 3.5 ecoboost
Anyone know if you can turn off/disable the Trailer Disconnect Alarm? Mine if I leave the lights hook up and lock my doors the alarm will go off within 5 min ever time. Ford of course has no clue as always! Thanks!
Orlando150
Orlando, FL
Ford
Trail is a 4x2 driving mode for light offroad. It's the only offroad option on 4x2.
https://www.fordservicecontent.com/...&userMarket=usa&div=f&vFilteringEnabled=False
Merccat
Ryan
2021 Space White Lariat SCAB 5.0 4x2
That explains it! I had my alarm go off twice while using a rental trailer the other day. I had it connected with the adapter if that makes any difference and just figured that it was flaky but it was all securely connected.
Platinum Peasant
West Sacramento
I received 2 OTA updates in recent days. Now, some of the modules that were there before in Forscan are gone. IPC being one of them. I literally cannot revert the track back to stock.
21PlatPB
Jared
Chilliwack, B.C
2022 Volvo XC60 PHEV, 2021 GT500, 2015 Hellcat
Uh oh, I’ve received 2 OTA updates recently too and was just planning on putting the truck back to stock before I take it in for some warranty work. I’ll see if I’m missing modules tomorrow.
JediNut
Emmett
Rocklin, CA
'21 Ford F-150, '05 Harley Davidson Softail Deuce
Platinum Peasant
West Sacramento
Let me know please!
mil13r
Logan
Houston, TX
2021 XLT Sport 4X4
@Livnitup Curious if the below enables the mirror spotlights to be on over 5mph?
740/741-04-01xx**xxxxxx--SpotLight: 00=disabled, 01=enabled
thanks!
dmac
2015 Lariat Sport (sold)
Software
Trail seems to be a mode for medium speed trail driving. No lockers, higher rpms, and does not change you into or out of 4wd.
Platinum Peasant
West Sacramento
@Livnitup do you happen to know where factory (vin specific) as built modules can be downloaded? My 2 recent OTA updates have changed modules for me and IPC is gone all together.
ptricky
Texas, USA
2021 F-150
ryanc111
Ryan
Bozeman, MT
Leadfoot Powerboost
What adapter is everyone using? My Vgate Vlinker FS has been giving me problems. Even after updating to the latest firmware on the website. And on the 2.7 EB I can't even get into the IPC. And sometimes, I get hung up when its searching for any modules after OBDII module. Any help would be awesome. Ordered an OBD Link EX just in case if the cable is actually a hot pile of garbage.
Edit: Contacted Vgate and they gave me an unreleased firmware. Still having issues where I cannot get past OBDII when its checking for modules. This issue is intermittent.
Having the same issue with that adapter. Could never get it to read past the OBDII module like yourself. I sent it back to Amazon and had them send me a new one thinking it was a bad cable but the issue persists. I ended up using an older cable that my buddy had with the manual switch which is working for me for now.
I sure hope they eventually get the firmware dialed so the Vlinker FS works though.
