imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
I’m trying to make the changes I can’t open the ipma I think it my Bluetooth OBD2 connector or could it be something else
I had that issue with my Bluetooth adapter as well. I could connect to every other module and make changes though. Haven't had an issue since getting a wired ODBLink Ex cable though.
GolfR
2022 F150 KR PB
Yeah, I used Forscan to turn off the belt minder and I can drive across the job site without it alerting me to put on the seat belt, but that’s a new one. On my 15 it was two separate changes. Thanks again. Truly appreciated.
You can disable the Doo da Doo chime with
IPC 720-01-02 XXXX-X2XX
This gets rid of the startup chime but if you set this there doesn’t seem to be any way to disable the seat belt minder. Seems to be one or the other.
dben18
NC
2021 F150 XLT 3.5L Ecoboost 4WD 302a Supercrew
@Livnitup I am brand new to forscan. I have all recommended software, adapter, etc. Step 1 - I was in process of saving all my original as built modules (actually finished saving them all as stated) then noticed in the vehicle and interface information that I have a few (!) in my log. DTCs. I am wondering why this is, as I have just begun this all for the first time ever. I also wanted to state that I had an aftermarket sound system (4 new door speakers, tweeters, and 5 channel amp with 10" sub installed a year ago when I got the truck. (2021 XLT 3.5 ecoboost)... Could this be what is throwing some of these (!) (is it DTcs..?) in the "log".
DTCs in TRM: U0143:87-0B
DTCs in CCM: C1A67:97-28
DTCs in ABS: C1013:7A-68, C0031:01-28
DTCs in ACM: B1A01:13-0B, B1A02:13-0B, B1A03:13-0B, B1A04-0B
I have stopped from continuing anything until this question is answered. What are these (DTCs?) what do they mean - can this be from my aftermarket sound system and them hooking that all up. Will this hinder doing anything like disabling double honk, bambi mode, adjusting tire size (I just got 285s, 65, 20 on stock sport wheels) - relearning shift patterns, and more and more that I was excited to do?
I apologize that this is a long post, and may be in the wrong area of the forum to post. I appreciate anybody else chiming in on this all. I am open to giving my VIN if need be.
dben18
NC
@Livnitup More information in regards to my post above. I have just found this information.^
Code: U0143 - Lost Communication With Body Control Module C
Additional Fault Symptom:
- Missing Message
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Trailer Module
Code: C1A67 - Forward Looking Sensor
- Component Or System Operation Obstructed Or Blocked
Status:
- Previously Set DTC - Not Present at Time of Request
Module: Cruise Control
Freeze Frame :
-GLOBTIM: 0 s - Global real time
-DIST_TOT_VEH: 0.0 km - Total Vehicle Distance
-MOD_SUP_V: 0.00 V - Module Supply Voltage
-ExtTemp: 87 °C - Outside temperature
Code: C1013 - Brake System Pressure
- Fluid Leak Or Seal Failure
Status:
- Test not complete
Module: Antilock braking system
Freeze Frame :
-TOTAL_TIME: 30591745 s - Total Time
-TOTAL_DIST: 16739.0 km - Total Distance
-IC_VPWR: 13.00 V - Instrument Cluster Power Supply
-AAT: 18 °C - Ambient Air Temperature
-PWR_MODE_KEY: Running (Position 2) - Power Mode Key State
-TOTAL_TIME: 30591746 s - Total Time
-IC_VPWR: 14.25 V - Instrument Cluster Power Supply
Code: C0031 - Left Front Wheel Speed Sensor
- General Electrical Failure
Status:
Freeze Frame :
-TOTAL_TIME: 30572458 s - Total Time
-IC_VPWR: 12.00 V - Instrument Cluster Power Supply
-PWR_MODE_KEY: error - Power Mode Key State
Code: B1A01 - Speaker #1,2,3,4
- Circuit Open
Status:
Module: Audio Control Module
Caneman88
Ron
San Antonio TX
2021 Powerboost F150 Platinum ,2009 370Z
Pella Windows and Doors
Have you tried this yet? Does it work ?
Yes I have done it and it works fine just don't have soft button for cams yet but works with hard button goes to hitch view than to bed cam
Canadianeh!
Marco
2021 f150 lariat
Oh nice then I gotta do it. But what do you mean by soft button ?
Livnitup
Livnitup
2021 F150 Platinum
The CCM DTC talking about the sensor being blocked - Did you put an aftermarket front bumper on or do anything that might be blocking the sensor that's above the driver side tow hook? Some of those DTCs seem serious but if it were me I would clear them, and see if they come back. If they do then I would take the truck to the dealership to have it diagnosed because those aren't the run-of-the-mill DTCs that pop up.
Livnitup
Livnitup
2021 F150 Platinum
I want to apologize for not keeping up with this thread as I would like to but I've been getting about 50 messages, emails, etc. per day across multiple sites and have been very busy in my personal life but I hope to do a better job of keeping up soon.
I've started work on a new HVAC spreadsheet located here for anyone interested:
Jesse-Infotainment
Jesse
2024 F150 Lightning Flash
DTCs in TRM: U0143:87-0B This is a standard DTC that even I have, there is a ssm about it
DTCs in CCM: C1A67:97-28 -
DTCDescriptionFault Trigger Condition
CCM C1A67:97Forward Looking Sensor: Component Or System Operation Obstructed Or Blocked Set by the CCM as a continuous memory and on-demand DTC if the CCM detects an obstruction or if the sensor is blocked. This DTC may also set when the CCM does not see a vehicle or object on the road for an extended period.
DTCs in ABS: C1013:7A-68 -
C1013:7ABrake System Pressure: Fluid Leak Or Seal FailureCO: ELECTRIC BRAKE BOOSTER (EBB) UNIT INTERNAL FAILURE (Anti-Lock Brake System (ABS) and Stability Control)
C0031:01-28-
C0031:01Left Front Wheel Speed Sensor: General Electrical FailureM: FRONT WHEEL SPEED SENSOR ELECTRICAL FAULTS (Anti-Lock Brake System (ABS) and Stability Control)
B1A01:13Speaker #1: Circuit OpenH: ONE OR MORE SPEAKER IS INOPERATIVE - ACM CONTROLLED 18 SPEAKER SYSTEM (Information and Entertainment System)
B1A02:13-0B -
B1A02:13Speaker #2: Circuit OpenH: ONE OR MORE SPEAKER IS INOPERATIVE - ACM CONTROLLED 18 SPEAKER SYSTEM (Information and Entertainment System)
B1A03:13-0B -
Hectort713
Hector
Houston, Tx
2021 Ford F-150 Tremor
I have a question trying to get this doubt out of mind, some are stating that for the 36 Gallon tank the mods to do is
max fuel range in the IPC as
720-03-01 xxx0 00x5 54xx
But according to my 2019 Ford F-150 is the other way around
720-03-01 xxx5 54x0 00xx who here can confirm, now my 2021 Tremor has a different code
720-03-01 xxx0 00x0 00xx and I’m supposed to have the 36 Gallon extended tank, but I fill like we are not getting what it’s supposed to be.
@Livnitup
@Nightshade @tonesto7
Platinum Peasant
West Sacramento
got this from another site:
Here's some things to try:
IPMA 706-02-02 xxxB CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-02 6xxx xxxx xx--
APIM 7D0-01-04 xxxx EDxx xx--
Do an APIM reset under the wrench icon after the APIM changes.
Just did this on mine and it worked. I had my IPMA module updated earlier today
Platinum Peasant
West Sacramento
@Jesse-Infotainment and @Livnitup huge thank you to you both for all the help you two give on these forums. Got my cameras working at speed tonight and its awesome to get some progress on this. Thank you!
Platinum Peasant
West Sacramento
Tried it today using the 2.3.45 software and made sure to check "auto increase" in the connection tab under settings. It completed the PCM relearn with no issues. I still have code U0131 under the ABS module and IPMA module so I need to figure out what they mean.
I tried this tonight with auto increase checked, and again, was told "access denied" and then "service procedure interrupted". Not sure if im locked out somehow... maybe because its diesel and Ford locked us out so we can't delete/tune? lol.
Jesse-Infotainment
Jesse
I would try to roll back to .43 and see. I’ve had all kinds of issues with 44 I didn’t install 45 yet.
I installed 44 and had to roll back
