Itaintfastenough
- First Name
- Woody
- May 14, 2024
- Grandview Texas
- 2020 Transit Connect, 2023 Lightning Pro ER
- Occupation
- HVAC Contractor
I installed all OEM bed light components, and like some others, it doesn't work. Here's why, and what needs to be done, to get the bed light switch to work as the factory intended. On the BCM, plug (not the module) # C2280E is missing the pin and wire in pin position 9. This wire connects to the green/orange wire on either side (doesn't matter) of the bed light wiring harness.(I chose the passenger side) Next, pin #8, on the same plug is there, but it's missing a wire that's tapped into pin #8's wire. This wire needs to run to the white/blue wire coming off the bed switch. Thats it...push the bed light switch, lights go on, push again and they fade to off...
