Anyone remove rear blocks to do a "reverse level"
Littlefield82
Holly Springs, NC
2021 Lariat 502a PB FX4 5.5'
Civil Engineer
I just got off the phone with my local Ford dealer and they quoted $35/per U-bolt for the 2 wheel drive ($140 total) and $8 for replacement nuts. If you have a 4x4 and want to ditch the longer bolts and use 2 wheel drive u bolts it's not a cheap mod. If you want to keep the longer 4x4 u bolts then make sure you have washers and a really long deep socket in order to tighten the nuts as there will be a lot of thread showing on the 4x4 u bolts.
FastHamFreddy
Fred
Alabama
2021 Ford F150 XLT
Project Manager
I removed the blocks on my 4x4, dropped it about an inch.
It won't really have any impact on towing, however, you may experience a reverse rake with heavier tong weight. I plan on installing airbag helper springs, simply because my last truck had them, and I really liked how that truck towed my camper.
Here is the process/photos: https://www.f150gen14.com/forum/threads/anyone-remove-rear-blocks.3779/post-109663
Did you need to adjust your headlights when you removed the rear blocks?
12Lariat21
2021 Lariat 502A
I have a 502A Lariat, so they are auto adjusted anyway, so for me...No.
I wouldn't think that 1" would be enough to change your headlight angle where you would need to readjust it, anyway. But could be something you want to check on.
