Blainestang
A quote from Linda Zhang caught my eye just now:
The official Lightning Tech Specs says the 80A bi-directional charging station is optional on the Standard Range trucks, so I had assumed that meant it would work bi-directionally, and not just be an over-sized single-direction charger for the Standard Range truck (that's limited to 48A anyway).
Has anyone at Ford ever *specifically* said that the Standard Range trucks will have bi-directional charging capabilities, too?
Maybe it's a misunderstanding because the 80A bi-directional charger is standard on the Extended Range trucks, but I'm going to be pretty disappointed if I can't have bi-directional charging on a Standard Range truck.
Source: https://www.thedrive.com/news/43203/the-ford-f-150-lightning-will-be-able-to-charge-other-lightnings
Why did she specify "with the extended range batteries"?We ended up with something called Intelligent Backup Power. It uses the Lightning's actual charging port on the side of the truck, where you plug it in to charge, to do bidirectional power transfer with the extended range batteries, turning the truck into a mobile backup generator on wheels for an entire home ecosystem paired with a home inverter."
