Bluetooth Carplay Audio Not Working
sdchris
San Diego
2023 Platinum
My carplay bluetooth audio often doesn't play any sound half the time. I try connecting to the usb cable when it doesn't work and it still doesn't play any sound despite the apple music app showing the song playing. The only resolution I've found is to turn the car off and then on to get it working again. Does anyone else have this issue with the audio not working and found an easy solution?
Another fix I tried this morning was to completely shut off bluetooth from the Apple settings and plug into usb. However, I prefer not to fuss with my phone much while driving.
ctuan13
Chuck
Pittsburgh, PA
I'm assuming you've already tried a forced reset of the Sync system and a 12V reset as well?
sdchris
sdchris
San Diego
2023 Platinum
I haven't tried either. I've done a sync reset before and can try it. What is the 12V reset?
Diconnect the negative cable from the 12 v battery about 10 minutes. Make sure you don't have an update in progress and you'll have to close the hood manually after you reconnect the battery. The hood will reset after you close it. Hopefully the buggy software and modules will too.
BlueLightning
Thomas
Oklahoma
2023 Ford F150 ⚡XLT SR
I just restart my phone and it corrects the sound. The truck sync feeds off the phone. Sometimes it gets confused on what to do. lol.
Mashedtators
2023 F150 Lightning
Not sure if you use one but I have to turn off my VPN for the audio to work.
Al_V
Allen
Canton, Ohio
There was another thread recently about this.
Usually one of these 2 options temporarily corrects the problem:
1. On phone, turn off carplay then back on.
OR
2. Stop and turn off truck, open door, close door and restart truck.
htobin
Howard
Ovalo TX
F150 Lightning
It's been a very common problem for me. The suggestions above usually work. Strangely enough, sometimes the map will work, but I can't get Pandora to work. In my case, I wear hearing aids, which are connected to the phone by Bluetooth and I sometimes suspected that may be the issue.
Usingelectrons
Jake
‘24 Lariat ER
This happens to me a lot as well. I always just turn off CarPlay on the truck menu and turn it back on, works 95% of the time. Soft reset of sync gets the remaining 5%.
sdchris
sdchris
San Diego
2023 Platinum
I'm going to try turning off carplay and then back on when this occurs.
You note CarPlay and Bluetooth. I think it is likely mixing words, but CarPlay connects to the truck via a Wifi connection. Does it also use Bluetooth still for music or does it play everything over the Wifi connection?
Truly I don't think this will change nor fix the issue, but if your digging deep to troubleshoot, I'm not sure Bluetooth is the protocol at fault.
CarPlay seems to have different issues for different people. I fought some of the same issues. I couldn't be happier since I gave up on wireless, and it's not just plugging into a cable. The problems didn't go away until I reset CarPlay on the phone and told it to use wired connections only. I plug in every time I get in the truck, but it works every single time now and I got rid of that daily frustration.
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
My wireless CarPlay continues to be completely unreliable often resulting in some sort of fix
  • resetting infotainment system
  • toggling wi-fi on/off
  • restarting vehicle
  • plugging in phone
Very frustrating. And what made it more frustrating was I just rented a Toyota Corolla on vacation - a bare bones car with wireless CarPlay and it worked flawlessly.
Shame on Ford for not having a fix by now.
BlueLightning
Thomas
Oklahoma
Yep, updated iPhone to 18.4 and CarPlay says “Error, try again later” when attempting to send text. Music and phone work through Sync?
CyclopsThere
Portland
2023 XLT
So I have this happen from time to time. The 100% solution for me has been:
1) STOP any other music streaming from phone. If I was streaming to house speakers or headphones, I make sure to switch back to phone-only prior to getting in the truck. I suspect some of my issues came from the phone not sure which "device" to stream to. I don't want it to have to decide.
2) If carplay pops up, music is streaming, and still no sound, go to Phone List on the ford screen, click the carplay icon next to my phone to disable, wait a sec, and click the carplay icon to re-enable.
This solves the sound-out issue for me 100% since I've started doing it
